I did an update to Fitbit One Firmware 6.64 per the instruction of Fitbit due to an error I was having turning the fitbit on. After I did the update, the fitbit will not turn on at all. Occasionally when I connect it to the charger, it will say 6.64 and show a full battery level, but every time I take if off the charger it will not even turn on at all. I have tried the reset process and endless amount of times and off the charger it will never turn on and it will only turn on occasionally on the charger. I followed the instruction of fitbit and totally deleted the application, created a new profile and started from zero, which they advised me to do to ensure I have the most updated firmware. Well, after that the device will not work at all and I cannot get anywhere with customer support who advised me to follow their process. Anyone with any suggestions would greatly be appreciated.
I am not out of the woods yet. I think it's the battery, Was working and then the screen display went dark again. Back to the charger but not holding out high hopes.
15:28
12:13
JuanJoFitbit
08-07-2019
15:28
12:13
JuanJoFitbit
@NavyNurse91 unfortunately, Fitbit hasn't sold the One for years, any new ones purchased are "new/old" stock and they'll lose battery life even if sitting unused in a box. Since they've not been manufactured in over 3 years and batteries last 3-4 years at best, you probably bought a dead one. You'll have to either buy a current unit or buy an aftermarket replacement battery (*what I did). Thank you for your service.
@Jeri_D if resetting isn't working, your battery is probably dead. you can buy an inspire (non-HR) with a clip to get the closest resembled unit, or if inspired (pun intended) to do so, you can replace the battery with an aftermarket one, I've included instructions earlier in this thread.
Moderator edit: merged reply
Best AnswerI did an update to Fitbit One Firmware 6.64 and after I did the update, the fitbit will not turn on at all. Occasionally when I connect it to the charger, it will say 6.64 and show a full battery level, but every time I take if off the charger it will not even turn on at all. I have tried the reset process and still no response
6.64 seems to have killed mine as well... Tried all the steps ... tried the chat desk... Exactly the same problems as all the others. Nothing wrong with it until 6.64! Tried the restart options; tried to use laptop, Ipad etc. I am so annoyed that Fitbit would do this and it seems so suspicious that an update can destroy so many Ones.
Best AnswerGot a new Fitbit One and am having the same issue as others....plugged into charger it will turn on and read 6.64 and show full battery but when taken out of charger it is blank and will not come on...
Best AnswerI’m having this same issue, just took the new Fitbit one out of the box last night, charged it and started the setup process this morning. Got it setup with my app, it only turns on while plugged in. Have tried many times to reset it without any luck. Very disappointed, this needs a fix or I need a replacement.
13:02
12:14
JuanJoFitbit
09-10-2019
13:02
12:14
JuanJoFitbit
I bought an Alta hr. Hate it! Doesn’t track all my steps either.
Fitbit needs to send us all new ones. Ones that work.
Best AnswerI'm with you on the bracelets. I finally broke down and bought the Inspire. I carry it in my pocket the same as I did with my One and its works fine. I let Fitbit know I wasn't pleased that my One stopped working and they gave me 25% off for the Inspire even though the One was way out of warranty.
Best AnswerMy friend just gave me her unoppend fit bit one. I was able to connect it through the app but that was it. It won't turn on. Nothing happens. At first i thought it was because it was not charged. However after 7 hours, nothing comes up. I tap, have reset it and nothing. The most I got once was the picture of a battert, Any help would be great.
Best AnswerI replaced the battery but if you try this please be aware that the wires are so thin that you can strip the insulation off of the wire. I have **ahem**. wire bare and soldered on board. The negative is on but hard to see. All very small parts for big hands. But it works I have had to go in and move things around but I think I have it working again. So putting a new battery in per @Williger's instructions does work.
Wishing you luck
