04-23-2016
08:24
20:16
EstuardoFitbit
04-23-2016
08:24
20:16
EstuardoFitbit
I used to be able to get 7-8 days of daily use out of my Fitbit One with a full charge. Now it lasts less than 36 hours. Is there anything I can do besides replacing the One?
Best Answer04-23-2016 08:54
04-23-2016 08:54
Hi @Kerrythenurse welcome to the Forums! The battery of the Fitbit One should last up to 10 days with normal use. So let me suggest you something, please take a look of the tips on this post to make the battery of your tracker last longer. And if after try those steps, this issue persists, I suggest you to get in touch with Fitbit Support, they will help you out with this.
Let me know the outcome!
