01-05-2018 11:56
01-05-2018 11:56
I had 13 minutes active doing my mini tram. Then I input 4 miles at 19 minutes and it totaled at 24 active. What is going on? I deleted it and tried to put it in again...will not work...even took a minute and another off! I met my 30 minute goal and it won't put that up accurately! This is the second time it's done this. Not happy...what can I do to fix problem.
Best Answer01-06-2018 10:13
01-06-2018 10:13
Biking should be entered in manually. Its not step based
Wendy | CA | Moto G6 Android
Best Answer01-06-2018 11:15
01-06-2018 11:15
Best Answer01-06-2018 11:16
01-06-2018 11:16
I did enter that manually but it does not add correctly to my active total.
Best Answer01-06-2018 11:18
01-06-2018 11:18
Strange thing is it put in a number but not the correct total.
