05-02-2016 08:51
05-02-2016 08:51
Hello,
So I know the flower indicate the level of activity and you are doing better if flower is grown-up, but you can't have it maxed-out all day, as you will drop-dead in the evening. So what is the usual grown percentage you try to keep your flower at most of the day time? 25%, 50% or different?
Thanks
Best Answer05-03-2016 14:03
05-03-2016 14:03
@StrayFeral Thanks for stopping by! As you already know the activity flower indicator will grow and shrink based on your recent activity. I always try to be active most of the day, getting the flower on a 75% or more. However, I'm not active all day long so on those hours in which I'm less active I always try to maintain it half way, a 50% so I will not feel bad about my activity. 50% is good for those hours because I'm not very active, but I'm not inactive. The good thing is that now we have the hourly activity tile which you can set up the times you want the feature to be active and it is about doing at least 250 steps every hour you are awake.
Hope this helps, let me know how it goes!
