01-31-2016 09:31
01-31-2016 09:31
I found a Fitbit one tracker on the ground. Is there any way to locate what account it's tied to and thus the owner? Or if that's not possible, how do I reset the tracker to factory default so it can be handed off to somebody else?
TIA
01-31-2016 09:40
01-31-2016 09:40
Hello @ML1234,
Welcome to the community!
If you contact Fitbit Support, they'll send you a label to return it to them. They are able to get the id off the tracker and contact the owner. Thanks for trying to track them down.
I hope this helps.
Frank | Washington, USA
Fitbit One, Ionic, Charge 2, Alta HR, Blaze, Surge, Flex, Flex 2, Zip, Ultra, Flyer, Aria, Aria 2 - Windows 10, Windows Phone
01-31-2016 09:40
01-31-2016 09:40
Hello @ML1234,
I hope this helps.
11-07-2016 10:54
11-07-2016 10:54
was this found in west brom
