02-25-2018 19:41
02-25-2018 19:41
I keep trying to correct the volume of water I drank today but each time I do, it adds to what I put in earlier. I tried to fix it several times today and all I did was keep adding to the figure. Now its showing a volume of water today that I wouldn't drink in several days! Is there a way to delete what's there and re-enter it? I have a FitBit One.
02-26-2018 06:52 - edited 02-26-2018 06:54
Yes, Go into the water section of your app and then tap/click on the entry for "Today",
On the next screen you'll see "Log History" with a water quantity below it. Tap/click on the water quantity (mine is in ounces) and it will open an edit screen where you can change the water quantity, measurement type and date. Change the water value to whatever you need and then use the back arrow at the top of the screen to back-out/store the new value.
