08-06-2017
11:47
20:21
EstuardoFitbit
08-06-2017
11:47
20:21
EstuardoFitbit
I misplaced my fit bit in my house. The battery is dead is there anyway I can find it?? Pls help. Thanks
Best Answer08-06-2017 14:44
08-06-2017 14:44
If the battery is dead it might be hard
But you could try this. there are apps to download.
https://help.fitbit.com/customer/portal/articles/1008670-i-lost-my-fitbit-tracker
Hopefully it has a bit of a charge left in it
Wendy | CA | Moto G6 Android
Best Answer08-07-2017 10:38
08-07-2017 10:38
@Ziggykleo Welcome to the Fitbit forums! Just as @WendyB said, it will be very hard to find it if the battery is dead.
However, it is very common that when a Fitbit One is misplaced; users will find it near the laundry. Sometimes these clip based trackers will wind up in the dirty clothes pile. So, I recommend searching there first!
Keep me posted! ![]()
Best Answer08-07-2017 11:16
08-07-2017 11:16
Best Answer08-07-2017 13:27
08-07-2017 13:27
I would do as @SantiR said and check the laundry.
I would also check your car as well as it could be there. But with a dead battery nothing will really help you to find it except for looking all over.
I do hope you find it
08-07-2017 13:29
08-07-2017 13:29
Also do you have animals? They have been known to eat them.
And if you do look under your couches and chairs maybe they played with it and batted it under the furniture.
