01-04-2018 21:13
01-04-2018 21:13
I can see the One device available for pairing, but "paring rejected by One" the One is rejecting my phone
01-05-2018 22:02
01-05-2018 22:02
Welcome to the community!
You're making this more complicated that it needs to be:
That's pretty much it. The Fitbit App will correctly establish the Bluetooth pairing.
Frank | Washington, USA
Fitbit One, Ionic, Charge 2, Alta HR, Blaze, Surge, Flex, Flex 2, Zip, Ultra, Flyer, Aria, Aria 2 - Windows 10, Windows Phone
01-06-2018 08:18
01-06-2018 08:18
@deepdrkchochip Thanks for participating in our Fitbit Community! Seems odd that your Fitbit One is not connecting with your phone. I would like to follow up and would like to know a couple of details: What is the model of your phone? Are you trying to connect your One with the phone that was connected with when it used to sync properly?
@PureEvil Thanks a lot for your contribution and help my friend!
See you both later! ![]()
Best Answer01-06-2018 09:22
01-06-2018 09:22
Best Answer01-07-2018 06:42
01-07-2018 06:42
Fitbit trackers do not behave like other Bluetooth devices. If you try to do conventional Bluetooth pairing with any Fitbit tracker, it'll respond with pairing rejected.
Instead, as suggested, just install and log on to the application. It'll get the Bluetooth id off your account information and establish the Bluetooth pairing on your behalf. If you have a new tracker, just go through the Fitbit App and add a new device. It'll save this id on to your account, so you can easily establish this on another device (computer, tablet, or phone).
Again, do not try to do conventional Bluetooth pairing with a Fitbit tracker; this is not the way it was designed to work.
I hope this help.
Best Answer01-07-2018 12:06
01-07-2018 12:06
Best Answer01-07-2018 13:34
01-07-2018 13:34
@deepdrkchochip wrote:
Give me an 800 number to call please.
Clicking the Help link at the bottom of any Fitbit page takes you to that information: In the U.S. it is: (877) 623-4997 Every day 4am-9pm PT
Best Answer01-08-2018 08:33
01-08-2018 08:33
Out of curiosity, does it work with your Samsung Galaxy Note?
You keep mentioning that it doesn't work with your Kindle Fire. I don't believe that the Kindle Fire is among the list of compatible devices, this is especially true since Kindle Fire devices run an very modified version of Android that lacks many of the Google services.
I'd expect it to work with your Note 5; I wouldn't expect it to work with your Kindle Fire.
Best Answer11-23-2019 13:46
11-23-2019 13:46
I'm having the same issue. All fitbits are saying rejected. Did you ever figure out what was going on with it? I also have a note 5
Best Answer12-24-2019 09:05
12-24-2019 09:05
no, not that easy. My phone will not pair with versa 2.
Best Answer01-16-2020 05:48
01-16-2020 05:48
My One keeps on getting rejected by my Motorola phone. It was synced but the last few days, I can't get it to do anything.
