07-10-2019 09:16
07-10-2019 09:16
My fitbit one will not pair. When I press and hold the button to pair - it just run the timer...display won't stay on long enough to be discovered. I have tried this a few time...same results.
07-10-2019 12:41
07-10-2019 12:41
I'm having this problem with my One as well. Just started today.
07-10-2019 19:01
07-10-2019 19:01
I was able to resolve my issue:
1). plug in your One as if you are charging it.
2). press & hold the button down for about 20-25 seconds to reset your One, while it's plugged in.
3). unplugged your One then press the button to turn it on.
4). go to the Fitbit app and add your device again. your phone should now recognize your One. as if installing it for the first time.
Hope this helps. I had to do this steps a couple times before I got it to work.
Good luck...
07-10-2019 21:56
07-10-2019 21:56
This worked for me as well. Thanks!
07-13-2019 15:18
07-13-2019 15:18
@keemohg any other suggestions? I've tried it 8 times. I'm desperate!
07-13-2019 22:51
07-13-2019 22:51
Hello @keemohg the reason the user is requested to press and hold the button is that as a new unit, Fitbit assumed that the unit is turned off, and the press and hold is the on switch. If setting up a Fitbit One that already is turned on, there is no reason to press and hold.
And the timer, this is your exercise recording mode.
