11-23-2017 10:36
11-23-2017 10:36
Fitbit one not charging. New charger bought but still not working. Now device is completely dead.
Best Answer11-24-2017 05:32
11-24-2017 05:32
Try holding the button on the Fitbit for 15-20 seconds on the charger, as you’re device might just be asleep.
if not, try using another Fitbit one charger cable.
11-24-2017 03:16
11-24-2017 03:16
How frustrating! Have you tried cleaning the contacts on the One?
Here's a list of other troubleshooting steps to try. Please let us know if any of these work for you.
Best Answer11-24-2017 03:57
11-24-2017 03:57
Best Answer11-24-2017 04:49
11-24-2017 04:49
It's a long shot, but the recommended swab with alcohol might remove oil buildup that a cloth would not.
11-24-2017 05:32
11-24-2017 05:32
11-24-2017 10:47
11-24-2017 10:47
11-24-2017 14:01
11-24-2017 14:01
You should mark my reply or whoever’s reply it was as a solution, so that people with the same problem as you find the awnser quickly.
12-16-2017 18:14
12-16-2017 18:14
This worked for me!! Thanks.
