06-29-2017 17:10
06-29-2017 17:10
WHERE DO I FIND THE PROPER CHARGING INSTRUCTIONS?
Best Answer06-29-2017 17:54
06-29-2017 17:54
Do you have the USB charge cable? You plug it into USB charger or computer. The fitbit One needs to be removed from the rubber holder/clip. The fitbit One has contacts on the bottom of the fat end that line up with the contacts in the USB dongle.
Best Answer06-29-2017 20:39
06-29-2017 20:39
Procedure right here
http://help.fitbit.com/articles/en_US/Help_article/1799
Also See this thread for charging best practices. If you are not charging it correctly you could be damaging the battery
https://community.fitbit.com/t5/Charge/Fitbit-charge-battery-problems/m-p/1323307#M53291
Wendy | CA | Moto G6 Android
Best Answer06-29-2017 20:40
06-29-2017 20:40
Also the manual is here:
