Washed my fit bit
I washed my fit bit and now it won't turn on
1 REPLY 1
You can find several tips in the community to hopefully solve this problem.
One of them is to put your Fitbit in a can of dry rice and leave it there overnight.
Search in the community for "wet" and you will find several posts.
Good luck!
