Hello @mantecawife, This is weird since you are setting up a lower weight goal, it should not show that you have gain weight. Can you share with me a screenshot of this? In this way I will be able to take a closer look and share with you any possible solution.
If you are wondering how to upload screenshot, is very simple, you just need to use the option in the upper tool bar in the writing screen of the post.
Hope to hear from you very soon and I'll be here for any additiona question you have.
