Thanks for stepping into the Community @LuckyPenny! It's fantastic to have you here.
The furthest the Fitbit can actually sync is 20 feet. As long as it is under 20 feet, it should be fine and sync correctly.
I hope you find this information useful! If you have any questions, please let me know. ![]()
09-05-2018
03:23
15:56
SantiR
09-05-2018
03:23
15:56
SantiR
why is my Fitbit not syncing if I turn on Bluetooth, I mean it worked last time so why should it not work this time? Th other thing is that my Fitbit is not syncing really well I put it under 1 ft and still not syncing at all! Please help me!
Moderator Edit: Format
@Ben0207 Welcome to the Fitbit Community! Thanks for sharing the experience you are having with your tracker not syncing.
Please make sure to check all of the syncing troubleshooting steps in order to sort this out. That should certainly help you out with that.
Also, please not that you need to have both Bluetooth and Internet connection in order to sync.
Hope this helps. Keep me posted! ![]()
