Search instead for
fitbit one not setting up says dongle unplugged but it isnt. usb port ok
trying to do initial set up and it says the dongle is unplugged.  it isnt.  it is in the usb port of my computer which is fine.  I tested it with another device to be sure.  Now what?
Accepted Solution
1 REPLY
read this article for suggestions  -  click
Alta HR in the U.S.A. retired others
Windows 8.1 and Android 8
Accepted Solution
