04-07-2017 17:48
04-07-2017 17:48
i connect my one to carger it stays on once i remove button press wont react
04-11-2017 08:11
04-11-2017 08:11
@santhoshds Thanks for joining the Fitbit family! I recommend performing a couple restarts on your One. This has helped other users in the past.
Also, how old is your Fitbit tracker and when was the first time you experienced this?
Try that out and keep me posted! ![]()
04-13-2017 08:43
04-13-2017 08:43
How long have you had the one for? Because after a while the ones battery may decrease. If it is a new Fitbit one, then gpthe battery may be dead. If you bought this directly from Fitbit, then you could ask for a new one, but if you bought a refurbished off of amazon or eBay than there is most likely nothing we could do to help
Best Answer04-13-2017 16:42
04-13-2017 16:42
for 8 months and restarting doesnt help
Best Answer04-14-2017 06:46
04-14-2017 06:46
Is it that you can not restart it because the button doesn't work? If so, let the one die, then plug it in until it is fully charged, then try again.
