08-18-2019 17:58
08-18-2019 17:58
My fitbit one is synced to my PC which is fine but when I travel it is not syncing because I am away from the PC. Then when I return, I usually have to re-sync because it has stopped syncing for two weeks or more. How do I sync my fitbit one with my i-phone 8 so that when I am traveling I am still able to sync, and will this affect my ability to still sync with my PC?
Best Answer08-19-2019 00:02
08-19-2019 00:02
It should be a case of installing the fitbit app to your iPhone and logging on with your existing ID and password. Then, whenever you open the app it will sync - as long as you have bluetooth on and have internet access.
Where it might be a problem is when you have both your iPhone and PC within range. To sync to your phone when in range of the PC you may need to turn off bluetooth on the PC to allow the phone to connect.
Best Answer08-19-2019 04:27
08-19-2019 04:27
