01-18-2019
12:46
13:05
01-18-2019
12:46
13:05
Fitbit Update 1/18/2019: If you see the Fitbit logo and error 001 on your tracker, please see this link and restart your tracker. This should resolve the issue. If you are still stuck, please let us know.
Actively managing your weight? Find accountability buddies on the Manage Weight board
03-18-2019 23:11
03-18-2019 23:11
Still doesn’t work after trying to reset multiple times... even let it sit on the charger for a while
Best Answer03-19-2019 14:27
03-19-2019 14:27
I have successfully reset my Charge 3 but it came back up with the wrong time. Will it correct?
Best Answer03-20-2019 11:51
03-20-2019 11:51
Best Answer03-22-2019 07:53 - edited 03-22-2019 07:53
Welcome on board @Cjm028! Thanks for already restarting your Charge 3. Since the restart hasn't worked, I'd recommend changing the clock face to a different one to see if this brings back the display. This process is done through the Fitbit app, so don't worry if the screen keeps displaying "001". Let me know the outcome!
Hi there @Mlh630 and @Jonestina2328! Since you both got in touch with our Support Team, if the steps provided by them don't work, please feel free to reply back to your support case so they can continue assisting you.
Catch you later guys!
Best Answer03-23-2019 12:45
03-23-2019 12:45
I have tried restarting with an 8 second hold and the longer 15 second hold. My Charge 3 still displays the logo and 001. What now?
Best Answer03-25-2019 07:09
03-25-2019 07:09
I had the 001 again this morning. I have worked with the help people three times over issue. It is annoying and the only way to fix it is to attach to charger and press button on the side until reset. I had it happen to me once when not at home and no way to fix. What in the world is wrong with it? I am on my fourth fitbit and maybe my last. I have had issues with all three types I owned.
03-25-2019 09:03
03-25-2019 09:03
Hello. I have also had the same problem with the Fitbit Logo and 001 for the first time today 25th March 2019. I followed your instructions and it seems back to normal. I will keep you updated. There is a question about what clock. Mine is the Analog stat. My battery life was approx. 7 days and I charge on a Friday, but today is Monday and it was already down to 41%. Not sure if that helps but it is what I noticed.
Thank you for your help it is very much appreciated. I will keep you updated if there is anything further.
I purchased my Fitbit Charge 3 on 12th February 2019.
Have an awesome day, kind regards.
03-25-2019 09:15
03-25-2019 09:15
KCsFamous,
The more your tracker syncs to your device (phone, tablet, etc), the more battery drain you're going to have. Also, if you toss and turn a lot at night, the screen will turn on more and that will drain the battery fast, too. And, of course, you can always reboot the tracker. Like most electronic devices, if they get in a programming loop, sometimes you just need to restart it.
03-27-2019 13:53
03-27-2019 13:53
It didn't do a thing. Another suggestion?
Best Answer03-28-2019 12:09 - edited 03-28-2019 12:12
Hi @astudentagain, welcome to the Community Forums! Since the restart hasn't worked, I'd recommend changing the clock face to a different one to see if this brings back the display. This process is done through the Fitbit app, so don't worry if the screen keeps displaying "001". Let me know the outcome.
Welcome to the Fitbit Community @LTCProf! Since you got in touch with our Support Team, I'd recommend getting back to them so they can continue assisting you. Please check your inbox to see the last reply from our Support Team.
Hi @KCsFamous! Thanks so much for keeping me updated my friend. I'm glad to hear everything seems to be going fine now.
Welcome to the Fitbit Community @JoyceJ! Sorry to hear about the issues you've been having with your Charge 3. I've seen that you got in touch with our Support Team after posting here. Please check your inbox.
Hello @James_Vierkant! Thanks for helping out! ![]()
Let me know if you need further assistance.
03-28-2019 13:27
03-28-2019 13:27
Best Answer03-29-2019 02:25
03-29-2019 02:25
Best Answer03-29-2019 05:38
03-29-2019 05:38
I turned off the all day report, I am no longer using it at night and recharging at about 35%. so far no problem. The last time I had about 35% and it went to the 001 and in minutes it went to 3% so I am going to try to stay ahead.
03-31-2019 00:37
03-31-2019 00:37
Mine is displaying 001, ive tried cleaning the ports but it isnt vibrating when the charger is attached and im not able to restart it!
Best Answer03-31-2019 04:38
03-31-2019 04:38
Mine did this too. I just kept trying and pressing the button on the side and it finally vibrated. I was on the line with a tech so I don't know if they did something too.
Best Answer03-31-2019 11:26
03-31-2019 11:26
I have tried to reset my tracker, I’ve got the 001 code on the screen. I’ve plug it into the computer and it hasn’t worked. I don’t know what to do now, please help
Best Answer03-31-2019 11:39
03-31-2019 11:39
call help or do the live chat they should be able to help.
03-31-2019
11:48
07:20
03-31-2019
11:48
07:20
This also happened to mine. I let it totally discharge and when I charged
it again, it was fine.
Moderator edit: removed personal information
Best Answer03-31-2019 12:09
03-31-2019 12:09
Unfortunately I can’t live chat as I’m from the UK.
Best Answer03-31-2019 12:29
03-31-2019 12:29
Thanks to the people who replayed my partner has been able to fix my Fitbit 🙂
