06-08-2016
09:35
20:15
06-08-2016
09:35
20:15
06-08-2016 10:11
06-08-2016 10:11
I am having this problem today too. And it's happened in the past a couple of times. I'm also not getting an update for hourly activity. Everything else has updated but not these 2 functions. Help?!
06-08-2016 14:31
06-08-2016 14:31
06-09-2016 04:56
06-09-2016 04:56
Just an update . . . I was able to get the active minutes to finally calculate along with the hourly activity. I use my phone for updates so I held the tracker right onto the phone and made sure that the phone didn't time out during the sync and finally the whole thing got updated. I have a feeling that the sync was updating in the phone but not updating to the website . . . anyway, it got resolved for me.
06-09-2016 08:00
06-09-2016 08:00
I am having the same issue with my Charge...spoke to Customer service and they advise to reset...did that and no change.....no one from Fitbit support has responded to this issue
06-09-2016 08:46
06-09-2016 08:46
07-01-2016 17:19
07-01-2016 17:19
I am currently using the Blaze and have experienced this issue on two separate occassions. My device stops recording/tracking active minutes once I reach 478 minutes. I set a timer and have run up to 600 minutes. I am wondering if this is something particular to the Blaze or simply my device? Has anyone else reported this issue?
Ron O
07-10-2016 16:58
07-10-2016 16:58
Mine will not record steps on the Stairmaster or the Eliptical. Help!
Best Answer09-01-2016 16:17
09-01-2016 16:17
Yes both my spouse and I have the blaze and I solved mine by doing a hard restart of both the phone and the blaze it worked for mine but not my spouses blaze. I have tried everything and cannot get the active minutes back
Best Answer09-01-2016 17:50
09-01-2016 17:50
Best Answer09-06-2016 08:12
09-06-2016 08:12
@tljacks8 @rontogburn @veneidig Welcome to our Community!
Hi everyone, I would like to clarify that active minutes are granted depending on the intensity of the activity you were performing specially if it a step based one and not for the length of it. Is not the same when you walked 15,000 steps during the day than when you walk 9,000 steps in one hour. You can read more about active minutes here. If this is not what your tracker is going through then please try restarting it.
@rontogburn When using a StairMaster or elliptical machine you aren't actually walking so your tracker might not detect steps for these activities but you can manually log them to have a record of the effort you did and the calories burned during the activity by following @Mcore's instructions here.
Let me know how it goes!
Best Answer07-12-2017 15:14
07-12-2017 15:14
My Alta HR is New I am having trouble syncing. resolved everything but the active minutes. My active minutes show 110 on the tracker but zero in my app. How do I resolve this?
08-04-2019 06:37
08-04-2019 06:37
Try putting your Fitbit in your pocket while on elliptical. 🙂
Best Answer08-29-2019 18:37
08-29-2019 18:37
My Versa has always calculated my minutes. I been using this watch for a while now and I usually have 30 to 80 minutes a day. For the past week, I have 0 minutes a day. My hourly steps and not calculating either. I am using Fitbit on my PC and cell phone and both are not working. I have reset my Versa twice. After the first reset I piled up 30 minutes, then the next day was 0. Even the 30 minutes from the day before went back to 0. Something is wrong.
09-25-2019 03:46
09-25-2019 03:46
I am also having that issue. I've done hard resets on my brand new charge 3, my app & my phone. I'm also having issues w/ the real live heart rate. Its recording on my fitbit but not displaying. Please advise & don't bother telling me to reset. Maybe it was the firmware update on the watch. How can that be undone?
Ty
12-30-2019 04:02
12-30-2019 04:02
Same issue here!
Best Answer02-09-2020 17:27
02-09-2020 17:27
I had 58 active minutes recorded, then it synced and sent me back to 0 active minutes. My fitbit has been strange since the recent update.
04-03-2020 11:59
04-03-2020 11:59
i did the restart and it is not working yet
04-03-2020 12:04
04-03-2020 12:04
Best Answer04-12-2020 14:37
04-12-2020 14:37
When you find this can you give instructions. I just got my fitbit yesterday and wore it on a 1.5 hour walk. I would love to know why active minutes are at 0
