06-08-2016
09:35
20:15
06-08-2016
09:35
20:15
04-12-2020 15:42
04-12-2020 15:42
It works one day and stops the others, I really appreciate if someone can help in this issue.
04-14-2020 16:48
04-14-2020 16:48
So, it is a software issue then. Should correct that.
04-23-2020 14:11
04-30-2020 06:51
04-30-2020 06:51
CHARGE 3 LONG RESTART
Plug the device into the charging cable. While the device is plugged into the charging cable, hold the button down for 15 seconds.
Remove your finger from button. Note: Device won't have a smiley face icon and should be off with a black screen.
Remove the device from the charging cable.
Plug the device into the charging cable again. The smiley face icon appears on the screen.
Best Answer05-11-2020 11:16
05-11-2020 11:16
Two days now my Fitbit as not done my hourly Activity it missed 1hour to day and yesterday it’s so annoying especially when I am trying to reach a goal this is not the first time this has happened please Fitbit get it sorted it’s being going on now far to long
Emirates
05-11-2020 11:19
05-11-2020 11:19
this is Emirates I am not a jogger I am a walker that’s way I get annoyed about my hourly steps being missed
Best Answer05-12-2020 12:39 - edited 05-12-2020 12:40
Same here.
I wish Fitbit would fix their defective products before moving onto making a new product. Instead of fixing their mistakes they carry their mistakes along with them to their next product line.
05-12-2020 12:42
05-12-2020 12:42
Same problem. Fitbit’s line of products has defective software they need to fix their product.
05-22-2020 16:55
05-22-2020 16:55
I clicked all the way in to the detailed graph of today's steps and when I backed out, the Active Minutes updated. Don't know if it was a fluke.
Best Answer05-24-2020 06:50 - edited 05-24-2020 16:18
We shouldn't have to continuously reset the device and reinstall the app over and over again. I noticed my minutes stopped being recorded when I upgraded to Premium. I walk/jog/hike my regular trails which used to give me up to 120 minutes to find I have zero. I will not be continuing the membership if this is what happens.
Update: I have reset my Fitbit and reinstalled the app twice each today to no avail. I still have zero fitness minutes after 2 hour walk/hike/jog for the past 2 weeks. I cannot recommend Fitbit after this and will consider a different fitness device sooner than later.
05-24-2020 15:56
05-24-2020 15:56
I bought another watch, not a Fitbit. I still like Fitbit in comparison but I need something reliable
05-25-2020 05:46
05-25-2020 05:46
05-25-2020 07:39
05-25-2020 07:39
I gave up on the HR2 a couple of years ago and didn't replace it with a newer version. Too frustrated with what I had and resented the idea that I needed to "update" to get a working product. Glad I didn't based on what I'm seeing in these posts. . . looks like the newer versions would be just as frustrating. Fitbit losing out by not improving!! Fancy looking but not worth the money for the functionality. I'm an ex-Fitfit customer for sure!
06-05-2020 10:21
06-05-2020 10:21
Me too. Must be an error with Fitbit and not our devices so hopefully they will sort it soon.
Best Answer06-14-2020 08:20
06-14-2020 08:20
Hi my active minutes aren't recording either. I found going into settings on your device and choosing FORCE STOP for Fitbit works. When you reenter the app it updates. This does not last long. I have had to do it again the next day. I hope this helps.
Best Answer06-14-2020 09:42
06-14-2020 09:42
Not really . . . why should we have to continually reset, force stop, uninstall, reinstall in order to get proper activity reports? Totally disappointed with Fitbit.
06-14-2020 14:53
06-14-2020 14:53
06-16-2020 02:14
06-16-2020 02:14
Thank you fir posting this because I rally thought O was doing something wrong. I walk 2 to 5 miles on Amy given day. I noticed a week now my active minutes are stuck at zero. It’s frustrating
06-16-2020 03:21
06-16-2020 03:21
I finally gave up on wearing my Fitbit for this reason. What is the purpose of wearing one if it doesn't provide useful information?
06-18-2020 09:50
06-18-2020 09:50
I completed 50 minutes on a treadmill at 3mph and mine is registering 0 active minutes. I’ve tried resetting, updating, resyncing, nothing works.
