02-21-2017
10:04
10:13
02-21-2017
10:04
10:13
Can you add yoga as an activity to the charge 2!!?
02-21-2017 10:44
02-21-2017 10:44
Read above, if you already have 7 shortcuts you'll have to delete one before you can add Yoga (you can see the message at the bottom of the screenshot).
Not sure about iOS, but if you go to fitbit.com and then Dashboard, under settings, device settings you'll see the shortcuts.
02-21-2017 10:10
02-21-2017 10:22
02-21-2017 10:22
Best Answer02-21-2017 10:44
02-21-2017 10:44
02-21-2017 12:19
02-21-2017 12:19
Best Answer03-23-2017 20:36
03-23-2017 20:36
@WavyDavey I'm trying to follow the steps you mentioned here but I don't see an option for shortcuts or anything listing activities to edit under settings. In fact in both the app and the website I don't have many options at all under settings and none of them involve types of exercises or shortcuts....??
Best Answer03-23-2017 20:40
03-23-2017 20:40
@WavyDavey please help! Where is this menu? I'm on iPhone and I have tried the app and the website....
Best Answer03-23-2017 22:40
03-23-2017 22:40
Hi, @ashmack13. Sorry I should have been more clear. It's not in the app but in the fitbit.com web site Dashboard. Here is the link: https://www.fitbit.com/activities . Scroll down to the bottom and there's a link called Create Custom Activity. Once you've created the Custom Activity, you'll see the new custom entry under the search box (Log Activities). Hope this helps.
03-23-2017 23:56
03-23-2017 23:56
@ashmack13 do you want to add Yoga to the Multisport menu that can be found on the Charge-2?
Best Answer08-03-2017 09:13
08-03-2017 09:13
I did as the instruction stated and Yoga was added however, it is not showing up with my tiles or under exercise. Is there another step I am not finding;aware of?
Thank you for posting previous, it was very helpful.
Best Answer06-12-2018 18:17
06-12-2018 18:17
I still don't get it, I keep seeing "SOLVED! read above" but there isn't anything there. Specifically, how do you add yoga as an activity to the Fitbit Charge 2?
Best Answer01-15-2019 08:11
01-15-2019 08:11
Thank you for that link!
Best Answer01-15-2019 08:13
