05-20-2016
07:58
20:15
05-20-2016
07:58
20:15
05-20-2016 09:12
05-20-2016 09:12
Hello and welcome to the forums @Rb72
Since the Fitbit wouldn't be moving, it shouldn't add more burned calories than your sitting on the couch watching a movie.
Keep on stepping!
05-20-2016 14:17 - edited 05-20-2016 14:17
The safety instructions do say not to expose your Fitbit product to extremely high or low temperatures. Though I can't seem to find an actual number for what is too hot. It shouldn't affect the number of calories counted but it may damage the hardware.
I think it will depend on where you live and what that temperature typically is during the summer. I live in Kansas and I'd be weary to leave my Fitbit in the car during the day.
05-20-2016 22:25
05-21-2016 04:34
05-21-2016 04:34
Best Answer05-21-2016 08:44
05-21-2016 08:44
@Rb72 This article on burned calories may help you. click to read
Depends on how much stepping you did the day before. When I'm more active and burn more, my base line is higher the next day.
See if that helps explain it for you.
08-01-2019 14:27
08-01-2019 14:27
I work as a field biologist in the Mojave desert, in temps reaching 125 at times, and my current Fitbit has survived for over a year and a half. They're pretty resilient.
Best Answer02-18-2020 01:09
02-18-2020 01:09
I wore my Fitbit Versa in a very hot bath; and now it is not responding at all.
I've tried to reset it multiple times; and even tried to factory reset it. All to no avail.
Help?
