07-03-2016
12:21
20:15
07-03-2016
12:21
20:15
07-03-2016 13:28
07-03-2016 13:28
Hi, @SunsetRunner! A lot of people do seem to report the same issue. I would suggest getting in touch with Fitbit Support. If possible, include photos in your contact to expedite the process.
MakMak | Community Council
07-03-2016 13:28
07-03-2016 13:28
07-03-2016 13:59
07-03-2016 13:59
07-05-2016 10:10
07-05-2016 10:10
Same problem with my unit, band and the same age as your one. Got it as start of February this year.
Not a good display of product quality when so many are reporting this what seems to be, common issue with these rubberized straps.
07-08-2016 10:22
07-08-2016 10:22
I know what the problem is. Heat. If you are driving and the sun is making your arm warm, the fitbit is getting too hot. That causes the air bubble. These bands seperate because they get too hot. Mine is bubbled and fitbit only gave my 25% off. I am not really interested in 25% off a few more months of a poor quality device.
07-08-2016 10:43
07-08-2016 10:43
07-08-2016 20:32
07-08-2016 20:32
07-08-2016 20:43
07-08-2016 20:43
07-08-2016 20:59
07-08-2016 20:59
SalHynes
This happened to me and they sent a replacement fitbit. However how did you get it to sync with the fitbit connecter that was connected to your computer from your old one? How does it know to connect with the new one. No connecter was supplied with the replacement or instructions? Can you advise?
Best Answer07-08-2016 21:01
07-08-2016 21:01
07-09-2016 08:42
07-09-2016 08:42
Best Answer07-09-2016 09:00
07-09-2016 09:00
Best Answer07-09-2016 09:20
07-09-2016 09:20
07-12-2016 06:02
07-12-2016 06:02
07-14-2016 12:51 - edited 07-14-2016 12:52
Mine has had a bubble for about 2 months now, but it doesn't affect the sensor or anything. Mine's a year and a half old and was fine until I wore it on a 98 degree day and soaked it in sweat. However it doesn't seem to me something that's worth the hassle of getting a replacement when it's just a slight cosmetic issue and the sensors still work just fine. I've pushed, prodded, and poked all over it and it hasn't hurt anything. If it affected the sensor and accuracy of the device I'd replace it, but it's just fine.
07-14-2016 14:23
07-14-2016 14:23
07-27-2016 07:45 - edited 07-29-2016 09:40
Hello, @MusicHead, @Boss_Belle82! It is nice to see you around and a warm welcome to our new friend, @Twistngrind!
@MusicHead, Thanks for sharing your knowledge on how to set up a replacement with others, you are awesome! 😉
@Boss_Belle82, Thank you for your feedback we definitely try to improve the quality of our products based on your feedback.
@Twistngrind, I agree with you, what matters is on the inside not the outside, right? Just take good care of your buddy and it will not let you down! ![]()
07-27-2016 07:52
07-29-2016 10:03
