07-16-2019 12:38 - last edited on 11-17-2020 10:55 by MatthewFitbit
I no longer have an option on my dashboard to add or amend any alarms on my Fitbit since the new update? I simply cannot find any reference to alarm anywhere? Help
08-23-2020 09:06
08-23-2020 09:06
You now set your alarms on your fitbit - scroll left to Alarms and set them there!
08-23-2020 10:23
08-23-2020 10:23
08-23-2020 10:48
08-23-2020 10:48
How do you reboot it? And will you loose your currently saved data?
08-23-2020 12:26
08-23-2020 12:26
100% agree, setting the alarm from the device itself is SO unpractical.It's just not user friendly at all.Worse "upgrade" ever, we need that functionality back in the app.
A user survey would have been a good idea before integrating this change.
08-23-2020 12:59
08-23-2020 12:59
You could always set the alarm through the watch. That is not new. Yes, they upgraded the options — can now have recurring alarm etc. But you used to be able to do all that on the app, which was much easier for many of us.
08-24-2020 21:02
08-24-2020 21:02
There is no option on my tracker for an alarm. There is only an option to put it to sleep or DND. This is awful. There is no option on the app. Can anyone advise on this please? More and more with Fitbit is pushing me to just make the jump to the Apple Watch.
08-24-2020 23:12
08-24-2020 23:12
The only problem is my touchscreen on the charge 3 doesn't work so the only way I could set my alarm was through the app. I've only had my charge 3 for a year and a half before the touch screen stopped working. I swear I'm moving to an Apple Watch after this.
08-25-2020 13:53
08-25-2020 13:53
I agree! I can’t even figure out how to make sure it took the changes. And can you do more than 1?
08-26-2020 03:58
08-26-2020 03:58
I am still not able to locate my alarm setting in the app. After the update I even restarted my phone. The alarm part is still unavailable
08-26-2020 04:00
08-26-2020 04:00
It needs to be put back into the app. Doing this on the Fitbit is tedious
08-27-2020 11:09
08-27-2020 11:09
Looks like the new update did it again - no more silent alarms on my Charge 3... anyone have an idea how to get them back?
08-27-2020 11:41
08-27-2020 11:41
08-27-2020 14:47
08-27-2020 14:47
08-27-2020 15:23 - last edited on 08-27-2020 16:38 by LiliyaFitbit
Thanks for the help!
Best Regards,
08-27-2020 16:32
08-27-2020 16:32
Thanks Tracy! Unfortunately my touchscreen doesn't respond to taps 😞 my app was the only way I could set alarms. I've only had my watch a year and half too!
08-28-2020 09:01 - last edited on 09-21-2020 11:05 by LiliyaFitbit
If it is a charge 3 it should work by swiping and touching
Best Regards,
08-28-2020 09:16
08-28-2020 09:16
I updated my charge 3 and the silent alarm disappeared , I tape on the pic icon then the account and still no silent alarm, very upset that fitbit updates due this
08-29-2020 18:56
08-29-2020 18:56
I feel the same way . I’m trading my Fitbit for Apple Watch . I hate this new alarm setting and I was already having issues this the alarms since the previous update .
08-29-2020 18:57
08-29-2020 18:57
Exactly!!!!
08-29-2020 18:59
08-29-2020 18:59
Agree, VERY STUPID !!!!
