07-16-2019
12:38
10:55
07-16-2019
12:38
10:55
I no longer have an option on my dashboard to add or amend any alarms on my Fitbit since the new update? I simply cannot find any reference to alarm anywhere? Help
08-29-2020 18:59 - last edited on 09-21-2020 11:05 by LiliyaFitbit
No longer on the app... go to your fitbit and swipe until you get to
alarms... annoying but still there and available
Best Regards,
08-31-2020 16:34
08-31-2020 16:34
Best Answer08-31-2020 16:39
08-31-2020 16:39
Thanks for the tip ! What were they thinking when they decided to remove the application from the phone ???? I hope they recognize it was stupid and change it back ( but improved )
09-21-2020 09:41
09-21-2020 09:41
I agree completely, not easy to use.
Best Answer09-21-2020 09:43
09-21-2020 09:43
I plan to look for another device as having to set up the alarm on the device itself is nearly impossible.
Best Answer09-25-2020 00:50
09-25-2020 00:50
that's the issue, my charge 3's display does not work anymore, so this new "update" effectively bricks it... please software people, revert back so i can eddit in phone and not have to toss my fitbit to the garbage...
09-29-2020 06:49
09-29-2020 06:49
I lost the ability to have it turn on when I raise my wrist. I also do not know how to set up an alarm that reoccurs. If anybody could help me with that I would appreciate it please.
I totally agree that this last update was ridiculous and I am getting fed up with this thing.
Best Answer12-14-2020 00:10
12-14-2020 00:10
I dont have alarms either on tracker or app, just same options as you. A fix would be appropriate from fitbit right now!
This is my 3rd charge in less than a year...had to be replaced twice....regretting going with fitbit!
