12-05-2021
20:21
16:41
AndreaFitbit
12-05-2021
20:21
16:41
AndreaFitbit
I have had 4 alarms for years at 5, 7, 11 am and 4 pm. They are set to repeat all weekdays.
Suddenly they are randomly changing on me. Sometimes they’ll all change to read all 7. Or sometimes just 2 will change. today there were two 7’s. when I fixed one back to 5, they both became 5’s. It seems to happen after I charge. Sometimes rebooting will fix it. Syncing has no effect. Monday mornings are consistently bad.
12-06-2021 16:50
12-06-2021 16:50
Welcome to the Fitbit Community, @kpapalia. Thank you for letting us know about what's happening with your Charge 3 alarms and that you have already tried rebooting your tracker.
I would recommend removing all the Alarms on your Online Dashboard and then restarting your tracker again. Then set your alarms again on your Charge 3.
Keep on visiting the forums.
Best Answer12-06-2021 17:11
12-06-2021 17:11
I found the alarms in the online dashboard but I don’t see how to delete them. From what I can tell, all I can do is turn them off and on.
12-06-2021 17:19
12-06-2021 17:19
Thanks for getting back to us and for sharing your removing the Alarms inquiry @kpapalia.
To remove the Silent Alarms on the Online Dashboard click on the pencil on the right side of the alarm and then select Delete Alarm on the button.
Best Answer12-09-2021 07:20
12-09-2021 07:20
Best Answer12-09-2021 07:27
12-09-2021 07:27
