01-08-2019
14:26
20:07
01-08-2019
14:26
20:07
When I set an alarm it syncs with the Fitbit but within a short time the alarm turns itself off.
Moderator Edit: Updated Subject for Clarity
01-09-2019
13:01
05:31
01-09-2019
13:01
05:31
@Geoffb2 Welcome to the Fitbit forums! Thanks for taking the time to share the situation you have experienced with alarms on your Charge HR.
When you set up the alarms, are you syncing your tracker right after? This is how you do to make the changes effective. Check more details about alarms here.
If you are doing this, but the alarms are not going off, try restarting your Charge HR.
Hope this helps. Keep me posted! ![]()
Best Answer01-10-2019 10:51
01-10-2019 10:51
Best Answer01-16-2019 05:21
01-16-2019 05:21
I have previously replied and stated that your suggestions don’t work and I asked for further advice, which has not been forthcoming! Can someone please look at this problem again.
Best Answer01-25-2019 04:26
01-25-2019 04:26
I have done all you suggested and I still can’t set ab alarm.
