03-20-2022
06:23
09:53
AndreaFitbit
03-20-2022
06:23
09:53
AndreaFitbit
All my alarms have stopped working on my Charge 3. I’ve reset and still nothing. Also, some of them (I only have a total of 3 alarms) will double and then one disappears. So I’m constantly having to check to make sure the alarm I need is still there. Along with this now and they have stopped vibrating. I need help with both.
03-22-2022 11:32
03-22-2022 11:32
Welcome to the Fitbit Community, @GFKMK. Thank you for letting us know that you have restarted your Charge 3 to make your alarms work.
Please try setting your alarms through fitbit.com dashboard:
Does your Fitbit vibrate when you press the button?
Keep on visiting the forums.
08-12-2022 09:52
08-12-2022 09:52
No. It doesn’t even vibrate any more when I plug it in to charge. I have tried everything suggested in the community and nothing is working for me.
Best Answer08-12-2022 15:35
08-12-2022 15:35
Best Answer08-12-2022 18:12
08-12-2022 18:12
Best Answer08-13-2022 06:01
08-13-2022 06:01
Thanks for getting back to us and for your question @GFKMK.
If you're located in the U.S., chat is available 24 hours a day.
Best Answer08-13-2022 06:12
08-13-2022 06:12
08-13-2022 06:22
08-13-2022 06:22
Thanks for getting back to us and for letting us know that you already got in touch with our team @GFKMK.
Please let us know how it goes.
Best Answer12-02-2022 01:39
12-02-2022 01:39
Make sure the button on your tracker is aligned with the button opening on the charging cable. You'll know the connection is secure when the tracker vibrates and you see a battery icon on your tracker's display. Press and hold the button to restart your tracker: Press and hold the button on your tracker for 8 seconds.
Regards,
Will
