Anybody still have a working Charge 2?
Other than me?
16 REPLIES 16
Yes. I bought it April 23, 2018.
Yes, mine works great.
Mine is still going strong since 2016
Community Council Member
Wendy | CA | Moto G6 Android
@Andrew92
Mine had been workingfine for the past two years or more.  Its a bit battered these days, but going great otherwise, unlike my wife's Versa, which had to be replace 5 or 6 times in the first 10 months
Yes.  All good but noticed sleep record eg # of sleep hrs is not accurate...usually off by 1-2 hrs
Yeah, mine still works.  But useless as I depended on phone notifications which no longer work since IOS 13 update.
I do but have not downloaded update.
Me neither 😳
Sent from my iPhone
My Charge 2 is still working, but the band is broken AGAIN.
Not happy at all about the continual band breakage. They should be able to come up with a better band since there are others with this problem.
@PurpleRose4HIM ;
there are plenty of aftermarket bands available and to be honest, I always use those rather than the one that came with the Charge 2. They look better and are more comfortable too!
No.  It started not recording my BPM since last week and my sleep doesn't seem to be recorded properly.  I have to have it so my doctor can help advise and monitor my sleep.  I just wish can find a basic version that doesn't cost so much.
As per Fitbit support...go to settings on app and check sleep settings is
set to normal vs sensitive
My Fitbit is indicating I’m going to bed an hr earlier so they said to do
above
Asked if others have reported this error and told no.
BTW sensitive mode records your arm movements which contributes to restless
sleep record
Candise Arima
Amazon has bands, not expensive, metal clips instead of the plastic things that keep breaking.  Go for it!~  I love the new bands!
@CA27251 ,
I didn’t use Amazon, rather looked on e-bay, but I agree 100% with your views.  Much prefer those bands 🤪
I understand the struggle. The factory bands are not the best options for those who workout daily.
Yes myself and my husband have one each and they work fine.
