05-12-2019
07:13
11:08
05-12-2019
07:13
11:08
My Charge 3 battery life had diminished to less than 24 hrs. Now the battery is dead and it won't charge at all. I tried the reset procedure and nothing happens. I left it plugged into my device for 4 hours and nothing. Tried to reset again and still nothing.
05-12-2019 08:59
05-12-2019 08:59
My HR2 is doing the same, says 100% then within10mins battery drained and its dead. Also tried reset, nothing doing. How old is yours please?
Best Answer05-12-2019 09:01
05-12-2019 09:01
My HR2 is doing the same, says 100% then within 10 mins battery drained and its dead. Also tried reset, nothing doing. How old is yours please?
Best Answer05-12-2019 13:26
05-12-2019 13:26
Best Answer05-10-2020 10:30
05-10-2020 10:30
Mine also won't recharge. I've tried cleaning the terminals and the sensors on the back of the unit. Nothing. Mine is also only a couple of months old. Useless.
Best Answer05-10-2020 15:06
05-10-2020 15:06
Best Answer05-10-2020 17:15
05-10-2020 17:15
Hi mine is the same got it last year how do I fix it?
Best Answer05-10-2020 18:03
05-10-2020 18:03
My Charge 3 is a little over one year old and has never charged within the 2 hours. The battery lasts for 7 days (thankfully); however it takes days to charge to 99% (never 100%) and quickly goes down to 85% within 10 minutes of wearing the device. I follow the instructions for cleaning the sensors and the pins each time I charge it. Last year, I called customer support and they sent me a new charging cable which never improved the charging process. This weekend I cannot get the charge any higher than 45%. I also cannot reboot the device. The Charge 3 recharging process is very frustrating.
05-10-2020 18:36
05-10-2020 18:36
Best Answer05-10-2020 23:49
05-10-2020 23:49
i will try support and try and get new battery see how i go
thanks for that info
jackie
Best Answer06-21-2020 20:27
06-21-2020 20:27
My Charge 3 is 13 months old. Display is dimming and battery will not charge anymore. Fitbit will not replace. I am 3 weeks out of warranty. They offered 25% off another purchase. Why would I do that with no support for their devices? I really enjoy it, but not confident of the quality after so many have the issue. May be time to move on to another company/tracker.
09-16-2020 05:25
09-16-2020 05:25
Mine too!!!!
