03-17-2017 06:01 - last edited on 09-09-2020 09:49 by MatthewFitbit
Battery is fully charged but on my dashboard it says empty.
Restarted but it will not sync
03-17-2017 07:07 - edited 03-20-2017 04:26
I'm glad to see you around my friend @Charge2user1234! I'm pretty sure you're seeing the empty battery since your tracker isn't syncing yet, so it couldn't update the battery level appropriately.
Which platform are you using to sync? I'd recommend following the steps provided in this link in order to solve the syncing issue.
Let me know if this works!
01-12-2019 01:46
01-12-2019 01:46
Battery on my versa full but showing empty won't sync
