11-30-2017
14:51
18:54
11-30-2017
14:51
18:54
My Charge 2 is approx. 6 months old. It used to hold a charge for 4-5 days. Now it needs charged every night. If I forget, the thing goes dead. Is this normal or is something wrong with my Charge 2? If this is, in fact, a problem, where can I return it to get it repaired? Thanks for any help you can offer.
12-01-2017 08:14
12-01-2017 08:14
Hey @BoilerBoy, let me give you a warm welcome to the Community! Oh! Sounds bad that the battery of your Charge 2 isn't lasting as expected. As you mentioned, the battery of this tracker should last up to 5 days with normal use, so let me suggest you something, there are a few tips in this post that I'd like you to review to make the battery of your tracker lasts longer.
If the issue persists, let me know. 😉
12-08-2017 02:43
12-08-2017 02:43
Yes, I received an answer that satisfied me and learned something in the process.
12-08-2017 06:17
12-08-2017 06:17
Thanks for your reply @BoilerBoy! Sounds pretty cool that our Support team has helped you out with this issue. If you have further questions or comments, let me know, I'll be glad to help you out!
Have a nice day!
02-04-2019 20:24
02-04-2019 20:24
I've been dealing with the same issue for 2 months. Called and was told to buy a new charger. Wasted investment. I have to charge it 2-3 times a day most days. It's less than 2 years old. They have no plan to fix these issues. #disappointed
02-05-2019 06:09
02-05-2019 06:09
Hey @CreolePaula, let me give you a warm welcome to the Community! I appreciate the time you have taken to contact our Support team for further help. Let me ask you this, now that you bought a new charging cable, is the battery of your Charge 2 lasting as expected or still the battery draining in a matter of hours?
I'll be around!
02-05-2019 11:18
02-05-2019 11:18
Thank you for responding. No I am still having the same problems. I invested in the new charger but whether I use the old charger or the new one I get the same results. I have to charge 2 to 3 times a day in order to get results and it's still not tracking consistently or accurately. Not happy at all.
02-06-2019 05:12
02-06-2019 05:12
I appreciate your response @CreolePaula! Well, in this case, I can only suggest you to get in touch again with our Support team and let them know that the issue seems to be with the Charge 2 itself and not with the charging cable.
Let me know how it goes!
