Best screen protector brand for Charge 2.
I owned a fitbit since the zip. and ived been using this brand. I ordered mine already so my Charge 2 will be protected. IMG_5891.jpg
91 REPLIES 91
tried that, they did not replace?  How did you report the problem?
My first one I purchased from Amazon Kim a bit short of covering my screen and they just seem like they're very cheaply made. The ones I ended up buying and we're very pleased with me and my husband are Ace Armor Shield buy Protek California. They cover the whole screen and easy instructions to apply. I hope this helps
Where can I find tempered glass screen protector?
Please share if you've found a true glass screen protector for my Fitbit Charge 2?
Contact their customer service, ask for a supervisor, dont accept "25% discount", politely insist on replacement.
Does this really protect against breakage? I'm  on my  third  Charge 2 because the  screen  cracked  on the first two. Not covered by Fit it of course. Fortunately  had extra warranty  from the store. Has anyone  else had this problem?
I don't know, as I haven't picked one to try yet.
Sent from my Samsung Galaxy smartphone.
My Charge 2 is a year old and I wasn't aware of the screen protectors, now I have a smudge or maybe it's a light scratch on the face of the Charge 2. My question is how do you clean the face of the Charge 2? can I use a mild "Streak-Free Screen Cleaning solution" normally used on cell phones or laptop computers?  Sorry I did not start a new question but couldn't figure out how.  Anyone with ideas please HELP. I do not want to harm the surface of the Charge 2. Thank you everyone! Karen
Not sure.  I have used screen cleaner with no ill effects however.
Can i use a normal watch plastic for my fitbit screen?
I've heard that works as well, just cut to fit.
Will my fitbit screen become dirty if i try to take off the plastic?
Hello BrentC24, in my country (India) this costs $44.43 for a single one and $71.13 for two. That is way too expensive don't you think?:D
Definitely
I read many bad reviews about Shield protector. So, I’m confused now! Are you still happy using yours.
I haven't used the Shield brand Protectors.
Why have we not had screen protectors made available or come on the Fitbit’s like other watch style brands?
Which one are you referring to?  I just went through a lot to get a new fitbit charge 2 because of scratches on the screen.  I had used the screen protectors you use on your phone, those plastic ones that stick on.  But it didn't help.  Is that what you were referring to?  Or do you have another better suggestion?
On my first fitbit charge two and it scratched up all over screen.  Did you get any good suggestions on how to protect screen from scratch or cracks?  I have used the plastic ones you stick onto your phone (that often bubbles up)  Is that the armor one?  Cause if yes, that didn't do anything for me.
