09-02-2016 12:09 - last edited on 09-09-2020 10:26 by MatthewFitbit
I owned a fitbit since the zip. and ived been using this brand. I ordered mine already so my Charge 2 will be protected.
03-27-2017 12:01
03-27-2017 12:01
Is your DIY glass screen protector still working or have you had to replace it?
03-27-2017 13:05
03-27-2017 13:05
My DIY screen protector is still good as the day I put it on. On the other hand, the purchased screen protectors have started to peel off of my family's charge 2's.
And regarding tempered glass screen protector - they don't make it for curved screens like the fitbit. I used tempered glass screen protector on a phone where I'll be interacting with it heavily with my fingers... on the fitbit it's a waste even if it's available. A cheap DIY screen protector is more than adequate.
04-10-2017 14:08
04-10-2017 14:08
Do you know if they have the rigid face protector for sale anywhere in Canada? All I found are stick on cling things. The reviews are pitiful. They bubble, the curl up from the edges or just simply fall off. I'm looking for what you have for my new Charge 2 before I get a big scratch or rub on its face. Thanks.
04-17-2017 20:49
04-17-2017 20:49
Does anyone use a screen protector for their charge 2? If so, can you please advice which brand will work and where can I find it?
Many Thanks.
04-17-2017 20:55
04-17-2017 20:55
One thing I can tell you is that getting a generic phone screen protector and cutting it to fit does NOT work. It fell off right away, probably because the Charge 2's screen isn't flat like a phone. I've seen actual Charge 2 screen protectors online but haven't tried them. Curious to see if others have?
04-17-2017 20:55
04-17-2017 20:55
Hi!
I always by this brand. They stay on forever
Hope that helps!
Wendy | CA | Moto G6 Android
04-18-2017 00:00
04-18-2017 00:00
I have just purchased the following off Amazon, very impressed, easy to fet and you can't tell it is on there.
Fitbit Charge 2 Screen Protector, [6-Pack] DEGBIT® [NO-Peeling off] [Full Coverage] HD Clarity/Anti-Scratch/Anti-bubbles Installation Film Cover, Screen Protector for Fitbit Charge 2 -Lifetime Warranty
04-18-2017 03:49
04-18-2017 03:49
@EFTC I got the same one as @WendyB and am really happy with it.
EVERYONE should put a screen protector on their Charge 2. I don't know how my screen got a scratch on it, but this protector "healed" it. Meaning it covers it well.
Laurie | Maryland, USA
04-18-2017 05:32
04-18-2017 05:32
I used Armorsuit Military Shield
05-10-2017 12:37
05-10-2017 12:37
Oh my goddd the ace shield protectors cost 53,99$ on Amazon.ca WTF 😞
05-10-2017 13:07 - last edited on 05-15-2017 09:53 by HeydyF
The Charge 2 screen is not glass, so it's not going to crack easily like a phone screen. All you need is protection against scuffs/scratches - which a plastic film will handle nicely. The good ones won't yellow either.
There is one that had a lot of good reviews, so I got it. You apply it wet.
You get 6 in a pack, so if you do scratch it or it starts to peel, just pull it off and stick another one on. there is no adhesive, so they're easy to change.
Moderator edit: Removed advertisement information
05-12-2017 05:46
05-12-2017 05:46
As i have just become the proud owner of a charge 2, could you please tell me if is possible to brighten the screen so it is easier to see in sunlight.
05-13-2017 09:43
05-13-2017 09:43
@joolly it is preferable to ask an unrelated question in its own thread or at least in a tgread related to the question.
To answer, currently there is no brightness setting in the Charge 2 settings, so no it is not possible.
05-14-2017 13:29 - edited 05-14-2017 13:31
Those are NOT tempered glass screen protectors. Read the reviews
Curved tempered glass screen protectors is one engineering problem that has NOT been solved. People can't get good curved tempered glass protectors for curved phones like the Samsung S6 / S7 / S8 phones, or the iPhone with the 2D curved sides.
It is virtually impossible to make thin curved glass screen protectors without having them break during manufacturing / handling / shipping / application, and application of curved screen glass protectors is highly difficult due to the fact you must apply it 100% perfectly or the curved glass protector will not adhere properly (make contact in all areas) and leave air pockets all over the screen.
Please do not mislead people about false tempered glass screen protectors. Hoping this is not spam promotion above.
05-14-2017 13:33
05-14-2017 13:33
@SunsetRunner wrote:Do you know if they have the rigid face protector for sale anywhere in Canada? All I found are stick on cling things. The reviews are pitiful. They bubble, the curl up from the edges or just simply fall off. I'm looking for what you have for my new Charge 2 before I get a big scratch or rub on its face. Thanks.
Have you read my DIY post? My DIY screen protector is perfectly made and stays on perfectly, and has never peeled or come off. Cost pennies to make and lasts forever.
05-14-2017 13:59
05-14-2017 13:59
According to the description it is the highest quality tempered glass. I am not trying to mislead anyone. Just trying to help.
05-15-2017 20:52
05-15-2017 20:52
Someone posted earlier that they used clear cellophane tape aka scotch tape. I bought some tonight it went on pretty easy and they said it didn't damage the screen at all. You can just peel it off and put new on when needed.
One happy momma!
06-08-2017 16:18
06-08-2017 16:18
Hello, have a question. Are the screen saver suppose to be a little short or completely cover? I ordered some from Amazon and to me they seem short.
06-08-2017 16:41
06-08-2017 16:41
Mine is a little short too. But I love it. Wipes off easily and no scratches.
06-08-2017 20:28
06-08-2017 20:28
