03-20-2019 21:38 - last edited on 11-17-2020 11:22 by MatthewFitbit
I just got my Fitbit a couple days ago. I do HIIT workouts 4 days a week that consist of a 15-20 minute stretching warm-up, a 25-30 minute HIIT circuit, and a 3-5 minute finisher. Total of an hour each time. I know my Fitbit won't automatically track this (UGH) but I can just start a workout each day I'm at the gym. What's the best way to track? Set it up as an interval workout? Circuit training? Boot camp?
03-20-2019 23:27
03-20-2019 23:27
Hi @HNordtvedt Id suggest you use the 'workout' exercise shortcut and then change the name in the app after it has synced to HIIT. But I would only track the time you are actually doing HIIT, not the stretches beforehand, as the calorie count woukd be very different for stretching than the actual HIIT session.
Helen | Western Australia
03-25-2019 18:30
03-25-2019 18:30
Did that tonight and it worked just fine. Does it matter if I log it as a general workout as opposed to the Circuit Training or Interval Training options? Each interval is totally different. Cardio at one station, weights the next, etc .
03-04-2020 02:10
03-04-2020 02:10
sorry late to this! where is the 'workout' section on the app??
03-07-2020 06:57
03-07-2020 06:57
This two hundred dollar face less vibrating watch can’t do what the $20 Durr used to do And vibrate every 20 minutes.
Such is life.
03-25-2020 06:55
03-25-2020 06:55
On your Watch Under Exercise option
03-25-2020 06:57 - last edited on 12-04-2021 07:51 by AndreaFitbit
I set mine to do that. Can set it to track Laps by time, distance, calories, etc.
Moderator edit: format.
06-25-2020 00:59
06-25-2020 00:59
I don’t have the “workout” option on my watch under exercise? I only have run, swim, bike treadmill weights and interval so which would I pick when doing HITT training?
07-06-2020 14:09
07-06-2020 14:09
This is all I have as well....what do you log yours as?
08-12-2020 19:01
08-12-2020 19:01
Under account, go to exercise shortcuts, then you can only have 5 exercise shortcuts - delete one (or more) and it will allow you to add different exercises. No HIIT specifically, but circuit training, workout, or bootcamp may be more relevant.
11-05-2020 08:13
11-05-2020 08:13
Not OP, but thank you very much for sharing this! I had no idea there were other exercises one could enable. That helps a lot.
12-01-2021 13:56
12-01-2021 13:56
open your fitbit app in your phone and under account open charge 4 then open exercise shortcut there you can remove and add interval workout or circuit workout which are similar to HIIT.
01-05-2022 17:39 - last edited on 01-07-2022 18:14 by AndreaFitbit
I had NO idea I could do this! Thank you!
12-20-2022 03:03
12-20-2022 03:03
Hi, i am able to select the HIIT option, but every hiit training I do has different intervalls. Setting up the intervalls and keeping correct track of them would require a lot of configuration. Is there a way to just select hiit, without it keeping track of intervals, only time and my heartbeat? Or should i choose circuittraining then?
