09-09-2021
11:55
16:06
09-09-2021
11:55
16:06
Hello and thank you for your support,
I have a fitbit 4 and suddently the screen is black. I left it to charge for a lot of hours but nothing happened. I press the side button for 15 seconds while in charge, a smile appears but then nothing. It vibrates a lot but nothing in the screen, I have tried multiple times with or without the battery. The band vibrates but nothing in the screen. When is connected to charge the smile appears but then nothing. I have tried multiple tricks i found online but nothing.
Any suggestions?
09-09-2021 13:33
09-09-2021 13:33
Welcome to the Fitbit Community, @Suburian. It's great to have you here.
Thanks for the details about the screen and for the troubleshooting performed. Based on the information, it seems that this could be a glitch with the display since it's still vibrating and showing the smiley face. If your Charge 4 is still syncing with your phone, please try changing the clock face from the Fitbit app by tapping on your profile's picture > Charge 4 > Clock Faces.
Hope this helps!
09-09-2021 14:40
09-09-2021 14:40
Mine is doing the exact same thing. None of the online info works.
09-09-2021 16:39
09-09-2021 16:39
Likewise. Very sad tonight. 😞
09-09-2021 21:09
09-09-2021 21:09
I am having the same problem. But after a couple days of this my Fitbit won’t charge at all now. Kinda disappointed because it is only 8 months old won’t turn on, no buzz, no charge
09-09-2021 22:31
09-09-2021 22:31
Good morning,
since yesterday have the same problem.
First my Charge4 doesn't work.
I disconnectet my charge from the app and started Bluethooth again.
I did 3-5 times but it doesn't work.
09-10-2021 02:22
09-10-2021 02:22
Hello,
same problem here, just bought yesterday. After smile screen doing nothing.
Best Answer10-31-2021 10:12
10-31-2021 10:12
Same problem as above. Black screen and vibrates continuously for maybe 8 seconds or so when button is pressed. Then shows smiley face and black screen after that. Performs the same way with or without charging cable connected.
Phone won't sync to device anymore so cannot change clock face too.
Contacted support but all they could say was device is faulty without providing any form of advice or technical support except to check warranty status and throwing a 35% discount to purchase another fitbit device. Super disappointed with the fitbit customer support!
10-31-2021 10:33
10-31-2021 10:33
I experienced the same black screen and the 35% off to purchase another one. This is the second one I have had that only lasted about 6 1/2 months because Fitbit had to replace my original one because of a faulty band.
I agree, I am very disappointed with Fitbit customer support.
02-23-2022 09:30
02-23-2022 09:30
02-23-2022
i have the same issue as above, but it won’t let me sync the device to be able to change the clock face.
02-24-2022 01:59
02-24-2022 01:59
Best Answer08-18-2022 15:21
08-18-2022 15:21
I am on my 4th Fitbit now and this same issue just started for me. I love the Fitbit app and am super sad to lose all my achievements since 2016 but I'm done. I haven't had a single Fitbit make it to the two year mark without dying and all of them lost significant battery performance (needing to be charged daily) by the one year mark. Tomorrow, I'm going out and buying a Garmin.
08-31-2022 09:18
08-31-2022 09:18
Same issue. Like every Google product it dies with the warranty and no support is available.
09-30-2022 19:22
09-30-2022 19:22
This just happened to mine.
Purchased in 6/2021. I'm done with fitbit as well. This was my 5th. I think they do this on purpose so you keep buying.
11-07-2022 07:06
11-07-2022 07:06
Also purchased in June 2021 and just experienced this issue yesterday. I have swam with my Fitbit before but not regularly. After a long day of yard work, I was covered in dirt and grime so wore it in the shower for about 30 seconds then set it on the ledge. Came out to the black screen. So disappointed.
Best Answer11-10-2022 08:47
11-10-2022 08:47
Exactly the same happened with mine..very disappointed!
Best Answer11-10-2022 12:17
11-10-2022 12:17
I am having the same problem. My fitbit is less than 2 years old. First the band broke just after the warranty expired, so I gorilla glued the band onto the device. Now it won't hold a charge? This is ridiculous that the life span of this device is less than 2 years old. and it was not cheap!
I'm not sure I will be buying another fitbit device. My charge 2 lasted longer than this.
11-10-2022 14:39
11-10-2022 14:39
I went through the customer support chat and was offered the 35% discount (Pixel watch excluded). It doesn't look like you can pair it with other discounts though so the holiday sales may actually be about the same discount or in some cases a better deal.
I'm frustrated with Fitbit that this appears to be such a widespread issue and they simply don't care. IF I do decide to repurchase, I am definitely buying the 2-year replacement plan, but I don't know if I want to continue supporting the Fitbit brand
Signed,
(loyal customer for the last 10 years)
17:36
11:01
AndreaFitbit
11-17-2022
17:36
11:01
AndreaFitbit
my Fitbit 4 relaxed in the hot tub with me for about 5 minutes. When I plugged in the charger a happy face appeared. Help! Marcy
Moderator edit: format.
Best Answer11-18-2022 08:55
11-18-2022 08:55
After posting in another web forum, people suggested that I check with my credit card, as many cards have a benefit to extend a manufacturer's warranty by 1-year. The catch is that you need to have your device serial number, which is only on the box. The moral is: SAVE YOUR BOX!
P.S. I called Fitbit to see if they have record of my serial number and they do, but they REFUSE to give it to the consumer per "company policy". 100% Fitbit has lost me as a customer, and I will encourage everyone that I know and even people that I don't to NEVER BUY FROM FITBIT AGAIN.
