01-07-2019
15:24
13:05
01-07-2019
15:24
13:05
A couple weeks ago a black line appeared across the center of my screen, I thought it was just a glitch and would fix with the next update. Now some more lines have appeared at the top. Have tried resetting and restarting both my Fitbit and my phone (in case it was a syncing issue for some reason) nothing has gotten rid of this. I had bougth my Fitbit from Amazon.ca, so I am unsure what to do for returns or customer service. Thank you.
01-08-2019 09:36
01-08-2019 09:36
Hey there @CraigPiattelli, it's nice to see you around here! Thanks for restarting your Charge 3 and phone in order to sort this out. Nice way to go!
I have reached out to our support team and created a case regarding your inquiry. Someone will be reaching out to you within the next 24-72 hours with next steps. ![]()
Point me out if there's anything else I can do for you in the meantime.
Best Answer01-08-2019 09:36
01-08-2019 09:36
Best Answer01-16-2019 02:17
01-16-2019 02:17
I live in UK and was given a charge 3 for Christmas. Today I have a black line all the way down the middle of the screen. Have rebooted Fitbit and yet it’s still there.
Can anyone help please?
Thanks
Best Answer01-17-2019 04:41
01-17-2019 04:41
I’ve noticed my had developed a black line across the top part of the screen. Tried the usual things to sort it out but it’s still there...
Best Answer01-17-2019 08:37
01-17-2019 08:37
Start your own thread or contact customer support, they were very easy to deal with and helped me out.
Best Answer01-17-2019 09:19
01-17-2019 09:19
Contacted customer support and replied quickly. All sorted.
Best Answer01-17-2019 09:27
01-17-2019 09:27
I have the same problem.
A replacent unit is on its way.
But has anyone a idea wat is cousing this problem?
Bas
Best Answer01-19-2019 10:41
01-19-2019 10:41
Thank you
Best Answer02-12-2019 14:59
02-12-2019 14:59
Hello! I just saw that I had one line, restarted the device and now there are two lines 🤔 I haven't done an update yet... Should I? Thanks in advance!
Best Answer02-20-2019 02:33
02-20-2019 02:33
I had a black line appear across my screen yesterday, did all the resets over the phone, didn't work. Didn't think it would though as looks like dead pixels. They are sending a replacement, my only concern is its going to happen again as seems to be a common problem and there seems to be no fix except sending a new one....
Best Answer03-04-2019 17:41
03-04-2019 17:41
Hi. I also have this problem with a line across my screen. How do I resolve this issue? Do I need a replacement? I purchased my fitbit in January 2019.
Best Answer03-11-2019 18:14
03-11-2019 18:14
I also have lines across the top of my charge 3 screen. I restarted my phone and charge 3. I tried different clock faces, also. It is hard to see the steps at the top. Is there a way to fix this?
Best Answer03-19-2019 01:24
03-19-2019 01:24
My fix was clearly ,
Contacted support chat and they replaced the tracker.
It is proberly a hardware isseu.
Bas
03-19-2019
01:28
09:28
JuanJoFitbit
03-19-2019
01:28
09:28
JuanJoFitbit
Contact Fitbit direct and they will send a replacement.
My replacement is all working fine but reluctant to wear it whilst swimming as afraid it will happen again .... water may be the issue?? I should be able to as that’s what it’s for but welcome anyone’s thoughts / feedback? Thanks
Moderator edit: merged reply
03-19-2019 01:45
03-19-2019 01:45
For asfare as knie iT is not a water issue.
i swim with iT 2 to 3 times a week and Worms fine
bas
03-19-2019 13:19
03-19-2019 13:19
My replacement came as well but I’m afraid that it’ll happen again. Starting to think I should have just returned the watch and wait for the next version instead. This issue seems to be so prevalent it’s worrying.
03-20-2019 09:16
03-20-2019 09:16
I swim with mine all the time with no problems..
polly
03-23-2019 16:13
03-23-2019 16:13
I am having the same issue with black lines on my screen. So disappointing. Please help
03-24-2019 13:18
03-24-2019 13:18
Create your own post with it (like mine) and they will connect with you. I already got my replacement:)
Best Answer03-24-2019 13:21
03-24-2019 13:21
