01-07-2019
15:24
13:05
01-07-2019
15:24
13:05
A couple weeks ago a black line appeared across the center of my screen, I thought it was just a glitch and would fix with the next update. Now some more lines have appeared at the top. Have tried resetting and restarting both my Fitbit and my phone (in case it was a syncing issue for some reason) nothing has gotten rid of this. I had bougth my Fitbit from Amazon.ca, so I am unsure what to do for returns or customer service. Thank you.
11-23-2019 20:10
11-23-2019 20:10
My Charge 3 is now showing same black line as others described. I have loved my fitbits but with issue after issue i am very frustrated. Where would i find Customer Support phone#? I appreciate the Community support.
11-24-2019 10:05 - last edited on 07-02-2020 12:57 by LiliyaFitbit
Make your own post about it and the customer service will reach out.
12-04-2019 06:55
12-04-2019 06:55
Hi I'm having this problem too.
Resetting doesn't work and more lines are appearing.
Please let me know what I should be doing!
Thank you.
12-04-2019 07:29
12-04-2019 07:29
Best Answer12-04-2019 14:44
12-04-2019 14:44
Best Answer01-10-2020 21:32
01-10-2020 21:32
Hello,
I am also noticing black lines across my Fitbit Charge 3 and resetting my fitbit and phone has not solved it. I started off with just a couple but now they are slowly increasing in number. How would I go about resolving this issue or contacting customer service?
Thanks for your help!
01-11-2020 07:02
01-11-2020 07:02
01-11-2020 08:37
01-11-2020 08:37
Best Answer01-11-2020 08:52
01-11-2020 08:52
Best Answer01-20-2020 16:54
01-20-2020 16:54
Never swam or gotten mine wet, still got the black lines.
Best Answer01-21-2020 04:18
01-21-2020 04:18
Best Answer04-13-2020 10:35
04-13-2020 10:35
I am also experiencing this issue. A black line appeared about a week ago, as of today there are four lines across the top of the devices screen. Resetting the device has been fruitless, please advise.
Thank you.
04-13-2020 20:47
04-13-2020 20:47
Best Answer06-03-2020 15:01
06-03-2020 15:01
Hi there, I have a similar problem to others. My fitbit has developed horizontal black lines at the top of the screen. I have rebooted, changed watch faces and rebooted while plugged in. Originally the issue only arose when the battery was low but now it is constant. Thanks for any help you can provide.
Best Answer07-05-2020 12:38
07-05-2020 12:38
My Charge 3 which I bought last year had black lines running across the screen back in January. I contacted Fitbit and they sent me another Charge 3 which was working great until now. Now I have the same problem with black lines running across the screen and slowly getting worse every day. I will contact them again but I think I'm past the one year warranty. This seems to be a very common problem and must be a design flaw. I'm not a happy camper.
07-26-2020 05:43
07-26-2020 05:43
I contacted fitbit. Only offered me 25% off a new one. Bought it April 2019.
07-26-2020
07:18
08:24
AlvaroFitbit
07-26-2020
07:18
08:24
AlvaroFitbit
I contacted Customer Service on Friday. They offered to replace the Charge 3 or 50% off of a new model. Unfortunately the Charge 4 wasn’t eligible for the 50% off so I opted for the Charge 3 replacement. It’s been shipped and I’m supposed to receive it by tomorrow. I originally bought the Charge 3 last September so it is still under the one year warranty. Customer service was awesome. No hassles at all.
Moderator Edit: Personal info removed
Best Answer07-26-2020 08:13
07-26-2020 08:13
Mine has been doing the same thing with the black lines and I didn't think anything of it but now the screen in the top left corner has faded and it only gets worse so now I can barely see my screen. I restarted my fitbit many times but it's still getting worse. I love my fitbit so I just want to fix it as fast I can.
09:46
08:22
AlvaroFitbit
07-26-2020
09:46
08:22
AlvaroFitbit
It can’t be fixed. Contact customer service. If you are still under warranty they will send you a replacement.
08-05-2020 09:54
08-05-2020 09:54
There has been a dark line that has appeared on my charge 3 watch screen and I have tried everything that people on the website told me to do and nothing works. I have tried the long restart, changing watch face, the normal restart, and others. What should I do?
