Black screen on Charge 3
Hello,
since today I have a black screen on my Fitbit charge 3.
I already tried to reset a few times, and after a while I got a grey screen with verticale lines. But then it just went black again.
I also tried to change the clock, that didn’t work either, nor trying to restart it.
what can be te problem?
9 REPLIES 9
Welcome to the Fitbit Community, @valerie92.
I am sorry to hear your Charge 3 has a black screen. Thanks for trying to resolve this, I appreciate the additional details and I am here to help. Since you've tried to restart the tracker and change a clock face, I would like to confirm if you've tried doing a long restart:
  • Connect the device to the charging cable.
  • While the device is plugged into the charging cable, press and hold the button down for 15 seconds.
  • The device turns on and shows a battery icon. Two vibrations occur: first a short vibration, then a medium vibration
  • The device turns off.
  • The device turns on and shows a progress bar and short vibrations occur. The progress bar completes. Note: A total of 7 short vibrations occur.
  • Remove the device from the charging cable. The device shuts down.
  • Important: Plug the device into the charging cable again.
Looking forward to hearing back from you.
Hello,
Thank you for your reaction, I tried this already a couple of times. The screen does absolutely nothing, and it gives only two short vibrations in the beginning and nothing else.
Mine has gone too. This is the  3rd one I've had break  in just over a year and a half. Cant email them as not available anymore and live chat unavailable. Very disappointed 😞
Judie’s charge 3 is light grey and doesn’t react to reset or tapping. I’ve had on the charger with no response
I think it is dead
From Judy Allen
iI got a battery icon, pressed the button and got a clock face grey with a white line down the middle. Still not a black background
Mine's got a black screen too. This is my second replacement after my first Charge 3 had the grey vertical lines. Not happy at all considering these are not cheap products. Seems to be a design flaw which should be rectified...
How can I get a good black clock face like it had ?.
I am having the same problem with my Charge 3.  I tried the reset and when I put it on the charger and hold the button down for 15 seconds the device will buzz and then shut off.  Nothing appears on the screen.  I then take it off the charger, put it back on, but still nothing happens.  I have tried this several times hoping that something will come up on the screen but it doesn't.  One time it did keep buzzing for awhile after I took my finger off the button and unplugged it from the charger, but the screen remains blank.  This started on Friday with a full charge and after synching with my cell phone in the afternoon.  I had tried tapping it to see the time while I was swimming an hour or so earlier.  Something came up on the screen but I couldn't read it and after that the screen went black.  I have not been able to get anything to come up on the screen since.  I have only had this FitBit for about a year and a half.  I bought it to replace my Charge 2 which had been working fine for a couple of years because I had joined a swim club and the Charge 3 could be used in the pool.
HUH!! Must be something in the air!!! Mine did exactly same thing this afternoon: perhaps they’ve built in a drop dead feature??!!
John in MD
