01-31-2019
11:49
11:25
01-31-2019
11:49
11:25
Have had my Charge 3 for a month. This afternoon the screen doesn't show up when I press the side button. It is fully charged and is still vibrating and syncing with my app. I have tried restarting it as suggested here, but no success. Any thoughts?
02-01-2019 03:37 - edited 02-01-2019 03:37
Welcome on board @133deb, it's nice to see you around here! Thanks for already restarting your tracker in order to sort this out. Nice way to go!
Since your tracker is still syncing and vibrating, I'd recommend trying to change the current clock face to another one and see if this brings your screen back.
Once the screen is back, you can change your clock face to the default one.
Open the Fitbit app and tap or click the Account icon > Your device image > Clock Face (Clock Display on Android). If you change the clock face, sync your tracker to see the change.
Give this a shot and let me know the outcome!
02-08-2019 05:23
02-08-2019 05:23
Thank you for the help! I changed the face and it worked like a charm. Thankful to have found a solution as I really like my Charge 3!
Best Answer02-08-2019 06:34
02-08-2019 06:34
Great news @133deb! I'm glad to hear that your're back on track.
In case you have some spare time, I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
Best Answer04-05-2019 00:49
04-05-2019 00:49
I only have one clock face available to choose and it’s the one I used to have. It doesn’t let me choose another face. How do I reset it? I don’t want to lose any data.
Best Answer04-05-2019 12:43 - edited 04-05-2019 12:44
Hello there @DeeNied, thanks for jumping in here! If you only have one clock face available, choose that one or try logging out and logging back into your Fitbit app to see if there are more options available after that.
If you keep seeing only one option, choose that clock face and sync. Once the screen is back you can select a different one. The steps can be found at: How do I change the clock face on my Fitbit device?
Let me know how if this works for you. I'll be around!
Best Answer07-29-2019 03:28
07-29-2019 03:28
I woke up this morning my fit bit face was all distorted I switched on and off and now my screen remains blank it still connects to my phone I have tried to change clock face and nothing has happened please help xx
Best Answer07-29-2019 12:34
07-29-2019 12:34
Welcome to the Community Forums @Louise2424! Thanks for restarting your Charge 3 and changing the clock face to solve the issue with the black screen.
I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
Best Answer10-09-2019 22:04
10-09-2019 22:04
Hi there, my charge 3 is also blank with no change after a restart or changing **ahem** faces... could someone advise on resolution here please? Fitbit is still vibrating and syncing. Thank you!
10-09-2019 22:15
10-09-2019 22:15
Hi,
I've tried restarting, changing the clock face and performing the long restart but none of them seem to be working.
Please help!!!
10-10-2019 12:52
10-10-2019 12:52
Hi there @Giftyg and @LucyRhys, welcome to the Community Forums. I am sorry to hear that you are going through this situation. I appreciate the steps you've done so far in order to solve the blank screen.
Since none of the steps you tried have worked, I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
Let me know if there's anything else I may do to assist you with.
10-10-2019 13:06
10-10-2019 13:06
I also have the same issue. The side button causes the Fitbit to vibrate but it does not turn the screen on. The Fitbit is still syncing to my iPhone but changing clock faces does not turn the screen on. Interestingly, if I perform a reset of the device the screen will turn on and I can flip through the menus and even use the side button to come back out of sub-menus but as soon as I let the screen go black and press the side button again it does nothing. This appears to be a software problem given the side button works fine navigating back out of menus but it just won’t turn the screen on. Could you put me in touch with the support team to help me with my issue? Many thanks
10-10-2019 13:21
10-10-2019 13:21
I have had a blank face on my charge 3 X july when I did the update. I have changed clock face, I have tried to reset it.... I was once fwd to support- with no help or reply back... I am getting very mad with this update it has ruined my charge 3!!!
can someone help!!!
Best Answer10-10-2019 16:29
10-10-2019 16:29
I have tried the same suggestions and my screen is still blank. I tried to reset and now I can't pair my device to the app because I can't see the 4 digit code on my screen. I am at my wits end with this device.
10-11-2019 10:56
10-11-2019 10:56
Hi there @jma199- and @H-akers89, welcome on board. Thanks for troubleshooting your Charge 3 devices prior to contacting us.
I was about to create a support case on your behalf, but I've seen you contacted our Support Team after posting here and that they have helped you with this. Please keep an eye on your inbox for updates on your case.
Hello @giljones, welcome to the Community Forums. Thanks for all the steps you've tried so far to fix the blank screen of your Charge 3.
Since none of the steps you tried have worked, I went ahead and created a case for you with our Support Team. Someone will reach out to you soon to offer their assistance. Please keep a lookout in your inbox to the email address associated with this account.
I'll be around if there's anything else I may do to assist you with.
Best Answer10-12-2019 07:58
10-12-2019 07:58
Best Answer10-12-2019 08:02
10-12-2019 08:02
Hello there @H-akers89. Thanks for letting us know the outcome after contacting our Support Team.
Please don't forget that you can set up new your Charge 3 on your currently Fitbit account without losing any previous data by following the steps below:
I'll be around if you need more assistance. Keep me in the loop.
Best Answer10-20-2019 04:37
10-20-2019 04:37
Three days ago, my Charge 3 screen went blank. The fitbit still tracks movement, but I cant enter any exercise modes. Ive done soft and hard resets, as well as changed my face, but nothing has worked.
Please help.
Dan
Best Answer10-20-2019 04:43
10-20-2019 04:43
Best Answer10-20-2019 09:50
10-20-2019 09:50
I had this same exact problem but I unpaired my Charge 3 cause nothing was working. I’ve tried the long restart and the clock face change and nothing works. The watch vibrates but there is no display. So I can’t even pair it up again with my iPhone cause I can’t see the 4 digit code that shows in the display to type in my iPhone 😖 please help
