Brand Charge 2 - not charging, no battery icon
ANSWERED
Hi folks, My charge 2 is brand new and it simply won't charge.  I've tried using multiple USB ports on my laptop as well as my Galaxy phone charger.  It vibrates when I attach it to the ports and my phone appears to have located it but that's it!  No battery icon, nothing on screen and simply won't sync.  I've been reading through all of the help notes and none of them mention no icon at all.  I don't believe that the contacts would be dirty as it is brand new and I have jiggled it to ensure that it is connected properly.  I've tried holding the button down and just pressing it.  Is it possible that I have a faulty tracker or charger?  Thanks in advance for your advice.
1 BEST ANSWER
Accepted Solutions
Yes its possible to have a faultly tracker. I would take it back to where you got it and exchange it.
If bought at Fitbit then contact support
http://help.fitbit.com/?cu=1
Community Council Member
Wendy | CA | Moto G6 Android
19 REPLIES 19
Update - my tracker was faulty and a local retailer swapped it for a new one.  Thanks Wendy, I will.  Wanted to make sure that I hadn't missed something first!  Have a nice day.  : )
I had a very similar problem with my new battery charger not working properly. I had to press on the back of the charger for the battery symbol to appear. I called fitbit and had a pleasant conversation with two people. They said the charger was loose and immediately sent me a new one.  I had purchased my fitbit from Amazon.  The new charger made all the difference.
Morning - thank you, it turns out that mine was faulty.  I assume it was the tracker as there was no screen display but not 100% sure about this.  I too purchased mine on line, however it came with a docket directing me to a local electronics supplier if faulty.  I took it to them and it was swapped straight away for a new one.  The new one is perfect!  : )
I have gone through 4 new fitbit charge 2's but still wont charge.  I also bought a different charging cable and still wont charge!  It vibrates but still doesnt show the battery icon!
Have got the same problems, on my second new charge 2, with this one got a few steps into the set up process before message saying not enough battery to continue, I had the tracker plugged into​ my laptop the whole time , but no battery icon.it buzzes when clipped to charger but nothing else. Have made sure it is in correct position, have pressed the back, nothing works. Is there no solution to this as can't believe that the trackers can all be faulty? Sorry can't help, have you given in?
i returned all 4 fitbits!
Get Outlook for iOS
@melaq and @Sansue56 that buzz you feel is telling you that the tracker is charging. My thought is to use the phones charger, not a laptop that probably stops charging when the screen goes dark.
Until it is setup their will not be any indication on the screen.
I returned all of my 4 fitbits (they never worked).   They were new. I complained. They replaced. The new ones didn't work.
OMG! I feel as if I am going to be the same as you, second one not charging, no :battery: icon! If you don't mind me asking what brand of tracker are you thinking of getting now? Thanks Sue
Thanks for your advice, charged in wall socket overnight, and was able to finish set up and update tracker, all working well nowSmiley Happy
I'm on my fourth one and in still having the same issues. I think they recycle these defective ones. This is getting OLD.
I was using the phone charger on my last 3 devices and the technician told me to use the computer and not the wall charger. This is very frustrating.
i would return it!!!
Get Outlook for iOS
i lost my battery icon on my charge 2
You should be able to add it through the Charge 2 settings. The same way it was added before.
Thank you! I couldn't get the battery icon. I didn't know my laptop screen should not be dark. Now I have the icon and it's charging
Don't you have a wall brick you use to charge your phone @mjudyl
