11-23-2021
07:01
16:06
11-23-2021
07:01
16:06
Like I said in the subject, I got a brand new charge 4 about 3 weeks ago. I’m overall quite happy about the device but it does discharge quickly and now it started randomly alerting me that it’s not charging while I’m wearing it. It also says it while charging it now. Any ideas?
11-23-2021 08:46
11-23-2021 08:46
Hi, I had this too, howevwr I was on holiday and the fitbit was overheating. Not sure where you are located so not sure if yours is heat related. Never had any issues with previous Fitbits
11-23-2021
17:26
11:25
11-23-2021
17:26
11:25
@tnz @Mummahen Nice to see you both here. Thank you for you messages and feedback.
In your cases if you haven't done so yet, please give us a call or chat with us.
Click here to get connected.
See you around.
01-14-2022 11:24
01-14-2022 11:24
01-15-2022 09:21
01-15-2022 09:21
Having exactly same issue, fitbit stops tracking runs, is unresponsive until plugged into charger but shows 18% battery power left, looking at getting another brand now.
01-16-2022
16:27
11:25
01-16-2022
16:27
11:25
@Mummahen , Nice to see you back. Thank you for keeping me updated . I'm glad that the restart helped.
@Masterofinsanit , Nice to see you here. Thank you for your information.
When you the Charge 4 stops tracking are you using GPS? This could explain why the tracker stope recording. As the battery to low is to keep the GPS Connection.
Have you tried restarting your Charge 4. It seems to have helped our friend Mummahen
See yo around.
01-16-2022 22:59
01-16-2022 22:59
I think it happens when I sweat, it has happened again, but was not as bad as before (possibly because we're in winter).
01-17-2022 10:52
01-17-2022 10:52
Yes when using GPS but usually no less than 35% battery, never had this issue on any previous fitbit
01-17-2022
16:43
11:25
01-17-2022
16:43
11:25
@tnz , Nice to see you back. Thank you for your explanation. As recommended before, please give us a call or chat with us. Our team will be more than glad to have a look at this: Click here to get connected.
@Masterofinsanit , Thank you for your message and explanation. Does the situation occur when your Charge 4 is charged more? Have you tried it without the GPS ?
As stated before, if the battery level is too low the recording might be stopped to avoid that the trackers turns off die the low battery level. Remember that the GPS usage can cause that the battery drains faster.
Hope this helps.
01-17-2022 21:13
01-17-2022 21:13
I have had mine less than a year and it won’t hold a charge longer than 48 hours, even when charged overnight. Anyone else have this problem?
01-18-2022 00:33
01-18-2022 00:33
Good Morning
I've had my Charge 4 since September, my device also alerts me that my device is not charging while I'm wearing it & also while charging also. Can you assist me please ?
01-18-2022 00:44
01-18-2022 00:44
Bought hubby a Charge 4 for his birthday last year, discharges in 2 days!! What can we do to rectify this??
01-21-2022 05:13
01-21-2022 05:13
Are you suggesting that the battery must be seen as 'low' even before the Charge 4 states it is low? (it does that at 15%)
If so, why is either 1. the notification of the Charge 4 not being done when it is considered 'low' or 2. isn't the battery (management) not changed so it can function properly as long as it is not said to be 'low' or 3. any other solution.
What percentage should we consider as 'low' instead, while wainting for the proper solution?
If I interpret your message right you suggest the Charge 4 users to not use it below a certain percentage, this means the usable battery capacity is smaller than advertised/to be expected. This behaviour is considered "misleading".
01-21-2022 05:16 - edited 01-21-2022 05:36
@JuanFitbit The Charge 4 battery is considered 'low' (not even empty) at 15%. Your post suggest 15% is not the right value for considering the battery as 'empty'. What percentage should be considered as 'empty' and what percentage should be considered as 'low'?
edit:
This problem is adressed in this topic too:
01-22-2022 09:13
01-22-2022 09:13
Charged it overnight and on 100% went for a run and 1 mile in it stops tracking and turns off GPS 😭
01-23-2022
16:42
11:25
01-23-2022
16:42
11:25
@Masterofinsanit , Thank you for your message and update.
To everybody else. Thank you for your reports and updates. Please give us a call or chat with us, so that our team can have a closer look at each and every case to help you further. Click here to get connected.
@Gerwin1 , Thank you for your messages. It seems that there is a misunderstanding.
In order that the GPS records get fully recorded and that the tracker doesn't shut down during an activity that is using GPS, we recommend that the Charge 4 should at least have a 25 % battery charge.
Just keep in mind that the use of the GPS consumes the battery faster considerably.
See you around.
01-31-2022 05:42
01-31-2022 05:42
Dear @JuanFitbit,
As @Masterofinsanit mentioned 35% is not enough, I discovered tuesday last week that 44% was not enough and during my 5km walk yesterday it consumed almost 2/3rd of the battery capacity.
I'm allready charging it every other day (instead of every 7 days, as advertised)
This clearly looks like Fitbit has some serious troubles with their battery quality/selection and batterymanagement and possibly with GPS powerconsumption, in best case all the users on the forum who mention this are 'incidental'.
