03-28-2020
14:02
10:02
03-28-2020
14:02
10:02
Yes, my Charge 2 is also out of warranty and it broke on one side. Will the Charge 3 bands work on the Charge 2? I would love to get a Versa 2, but I should have gotten it when it was on sale.
TY
03-28-2020 14:08
03-28-2020 14:08
Charge 3 bands do not fit Charge 2. But Amazon usually has a variety of third-party band for all Fitbits.
03-30-2020 05:45
03-30-2020 05:45
Hi @KarenS0425, @JohnnyRow, is right. I have purchased a couple of fairly cheap replacements via Amazon and they have fitted OK and lasted as long or longer than the original.
03-31-2020 09:39
03-31-2020 09:39
Thanks for this information @Lilbiddy . Do you mind sharing which replacement brands you had luck with? I'm looking at POY and WePro on Amazon. Were either of these the replacement bands you purchased?
thanks!
03-31-2020 21:10
03-31-2020 21:10
Hi @BNKS, sorry but I can't remember which ones I used. I pretty much took pot luck. But as I said I haven't had a problem with either of them and to be honest they were cheap enough that if I had bought a dud set it wouldn't have hurt me. I think I just went for ones that Amazon stock rather than via Amazon for speed of delivery.
04-01-2020 13:26
04-01-2020 13:26
Thanks, Lilbiddy. This has been very helpful!
