07-10-2019
19:53
14:54
07-10-2019
19:53
14:54
The first time it happened, FitBit was great! They asked me to take pictures of my band and my Charge 2 and then sent a replacement band. But it's been a few months, and it happened again! This time I can see the problem, it's the side with the holes, not the buckle. and the end in front of the metal piece, both of the little squares are broken/breaking away from the main part of the band.
I researched this further and found that this is very common. I was thinking of upgrading to a Versa, but it happens with that watch too.
I was wondering if Gorilla Glue would help stabilize the little squares so that they wouldn't break.
07-10-2019 21:53
07-10-2019 21:53
Yep my band broke same place. I was very careful with the second band (Fitbit did not send me) and it lasted a bit longer but still broke. I have been using the silicone bands to keep it on...but that is not working well anymore. Can't keep buying bands or buy a new fitness tracker every few months....there should be a recall on these they are so bad.
07-11-2019 03:40
07-11-2019 03:40
I've had problems with broken bands over the years. My suggestion is to either go to the magnetic band or buy the generic bands off Ebay. I bought a set of 3 bands for under $20 from Ebay. When these are gone, I'm going to get the magnetic band. BTW, I have a Charge 2.
07-11-2019 07:00
07-11-2019 07:00
Have the generic bands broke?
07-11-2019 07:11
07-11-2019 07:11
Oh yes. I didn't expect them to last that long. I bought a lot of 3 in January for $6.77. The first one broke a few weeks ago. A lot of it has to do with the way I take it off I think. I bend the strap back and it starts to get a crease in it. Regardless, it's cheaper than a Fitbit band that will break at some point too. I'll get a magnetic band when these are done.
07-11-2019 07:15
07-11-2019 21:58
07-11-2019 21:58
I've never seen a magnetic band.
07-12-2019 04:05
07-12-2019 04:05
