05-17-2022
08:14
14:23
05-17-2022
08:14
14:23
SOOO Disappointed my Fitbit band connector piece snapped this morning getting ready for work. Not fixable. really disappointed in this quality. This is our 3rd Charge 4 connector to snap. My sons snapped with in 1 year and was replaced by warranty however it snapped again and then he had to buy the rubber wrist bands you put the fitbit face piece in. He doesnt like it - feels clunky. My fit bit charge is 22 months so Im past warranty. Its terrible that its so poorly made they snap like this after such a short time! I Dont want a clunky rubber band like my sons. any other options?
03-01-2023 05:57
03-01-2023 05:57
03-01-2023 06:04
03-01-2023 06:04
03-01-2023 10:41 - edited 03-01-2023 10:48
Hi!
This has saved my Fitbit! The band looks cool and fits very well. The Fitbit functions just as new! I hope this is helpful for you.
https://www.amazon.com/GOSETH-Compatible-Breathable-Shatter-Resistant-Protective/dp/B07HN4M9LJ
Eleni Pateras-Periolat Color Matches + Collagenwww.MakeupwithEleni.comlinktr.ee/eleni805
03-01-2023 19:53
03-01-2023 19:53
That’s brilliant! Thank you so much! Much better alternative then buying a new tracker.
Best Answer03-03-2023 00:56
03-03-2023 00:56
My Charge 4 broke the exact same way yesterday, I am fuming.
I will now put it in the drawer with the three Fitbit Charge 3's I have with dead screens.
Time to rethink my loyalty to the Fitbit brand.
What was it Albert Einstein said, "the definition of insanity is doing the same thing over and over and expecting different results".
03-03-2023 22:06
03-03-2023 22:06
Really tired of fitbit. I have had three. One stopped working, the second ones connector piece broke and now my third ones connector band broke. Why are they so cheaply made.
03-15-2023
11:05
08:28
DavideFitbit
03-15-2023
11:05
08:28
DavideFitbit
I have the same problem. Really disappointed. The first charge 4 had ran into battery issues. It would drain out completely in a few hours. Got a replacement - fast forward one year the band connector broke. And they are offering 35% off as a solution? This is a joke looking at the number of reports of the same issue.
Did you end up reporting it?
03-15-2023 13:06
03-15-2023 13:06
03-15-2023 13:36
03-15-2023 13:36
My replacement also snapped at the same spot 9 months later. But as it was past the 1 year timeline from when the original was purchased Fitbit said they will not replace it and no option to fix it. So disappointed.
03-19-2023 08:23
03-19-2023 08:23
Same here. 35% off? So bad. Mine is 1.5 years old.
03-23-2023 09:41
03-23-2023 09:41
I guess I am the latest addition to this unfortunate family whose fitbit charge 4 strap connector got broken and I'm unable to fix it. Please Fitbit help me.
Best Answer03-23-2023 10:02
03-23-2023 10:02
Not ideal.
But I bought this as a workaround. It helped resurrect my broken Fitbit until the next issue occurs.
Gheper Soft Watchband Compatible... https://www.amazon.co.uk/dp/B0BGXHLGCT?ref=ppx_pop_mob_ap_share
Best Answer04-21-2023 04:10
04-21-2023 04:10
The connector has just broken on mine. It's 2 months out of warranty. I don't want 35% off a new one, i want to have this one fixed. Poor show Fitbit 🤬
05-15-2023 13:48
05-15-2023 13:48
Yes same thing happened to me. I am so mad that I am only out warranty a bit and it is product issue that they won't replace this.
05-15-2023 15:23
05-15-2023 15:23
Best Answer05-15-2023 16:09
05-15-2023 16:09
Best Answer05-16-2023 00:03
05-16-2023 00:03
05-16-2023 02:52
05-16-2023 02:52
Best Answer05-16-2023 06:53
05-16-2023 06:53
05-16-2023 07:28
05-16-2023 07:28
Yes very disappointed. Fitbit should give us this band that encapsulates the Fitbit and we won't have to buy it on Amazon.
