07-26-2022
01:11
14:04
07-26-2022
01:11
14:04
Hello the lug on my charge 4 face has broken off. This means I cannot attach the stray on that side - so I can't wear it. Does anyone know if there is a repair service? Thank you.
07-29-2022 06:35
07-29-2022 06:35
07-29-2022 07:07
07-29-2022 07:07
07-29-2022 10:59
07-29-2022 10:59
07-29-2022 11:03
07-29-2022 11:03
07-29-2022 11:08
07-29-2022 11:08
07-29-2022 11:31
07-29-2022 11:31
Honestly don't know why they changed the lugs from metal to plastic of course they're gonna break or is that the whole point of them doing it. All about making more money by offering discounts on another one which is going to break as well. I wouldn't please them to give them any more of my hard earned cash and bought a replacement strap on amazon that the body of my charge 4 pushes into. Have had no problems with it and purchased another for a spare.
07-29-2022 12:49
07-29-2022 12:49
07-29-2022 13:02
07-29-2022 13:02
The strap I bought doesn't need the attachments. The bits you attach the strap to broke on mine also because they are plastic, ( they were metal on my charge 3 ) but you can buy a strap on Amazon which encases the actual fitbit so it doesn't matter if the attachments have broke off. You don't need to remove it from the strap to charge it either so once you pop it in its snug but can be removed if you want to. It's another option if you decide to get another charge 4 because the same thing will happen. They should have stuck with the metal lugs used on the charge 3.
07-29-2022 13:34
07-29-2022 13:34
07-29-2022 13:41
07-29-2022 13:41
07-29-2022 13:59
07-29-2022 13:59
Hope this helps
07-29-2022 18:02
07-29-2022 18:02
Hi, does that include UK 🤞
07-29-2022 19:06
07-29-2022 19:06
Yes it does. There is also a website called Ali Express and you can buy them there also for a about £2.50.(they're exactly the same) It's based in China and takes a few weeks to arrive so I ordered another spare strap there in a different colour as a backup.
07-29-2022 22:19
07-29-2022 22:19
