12-09-2021
05:55
16:06
12-09-2021
05:55
16:06
Expended calories appear to be irregular. For example, some days, I seem to burn more calories per step and other days, very few calories. What is going on?
12-09-2021 09:45
12-09-2021 09:45
Hello @SunsetRunner
The calories is a function of your heart rate, so the calories per step could be very different whether you are slowly walking or going fast up a hill.
Best Answer12-09-2021 09:45
12-09-2021 09:45
Hello @SunsetRunner
Best Answer12-10-2021 01:30
12-10-2021 01:30
HI Seb,
I thought so too but the disparity still raises questions. For example, some days my fat burn zone minutes seem to result in more calories being burned and other days, it will be the opposite. I thought the active zone minutes reflect heart rates, meaning the higher the zone, the more calories burned.
How does the counter work really?
Best Answer12-11-2021 08:17
12-11-2021 08:17
That is a good question. Nobody knows really as the formula is kept secret. In principle yes the higher the zone the more calories you spend.
A lot of fitness tracker overestimate Calories burned and Fitbit is no exception. To maintain my weight for example, I need to eat 20% less calories than what Fitbit tells me I burn, meaning for me it overestimates by 20%.
Best Answer12-13-2021 02:56
12-13-2021 02:56
Hi Seb,
Thank you for sharing. Much appreciated.
Charge 4 is a frustrating kit. I have to uninstall and reinstall. it often to get it to sync. I never did that when I used Charge 2.
I don't have a great deal of confidence in 4.
Best Answer03-01-2022 11:54
03-01-2022 11:54
I have noticed the same issue over the past few months. For the same workout, same length of time and very similar heart rate there is a huge difference in calories burned.
example:
day 1 body combat 60 mins, 147 avg bpm = 51 calories burnt
day 2 body combat 60mins, 154 avg bpm = 638 calories burnt
this is a huge variation and it is happening for all work outs. Swimming, weights, whatever it is, the stats are not comparable.
yes I’ve logged out and logged back in.
yes I’ve restarted my fitbit and the app.
Don’t understand how to get more accurate data.
03-03-2022 04:49
03-03-2022 04:49
I share your frustration. Charge 4 is an irritating kit. I had no problems with Charge 2 and only got a replacement because of problems with the straps. Accuracy of data on Charge 4 is questionable. I wish we could get official explanation for the shortcomings.
