04-11-2020 10:45 - last edited on 09-17-2020 15:30 by
I find it incredible that my charge 3 records the same Or even slightly lower number of calories burned for a good spinning workout as a walk with my dog!
The Fitbit shows a greater average heart rate, greater fat burn & peak zones during the spinning and other workouts. And yet -walking my dog seems to burn the same number of calories! 😂😂
04-11-2020 11:31
04-11-2020 11:31
Did you record these using the Exercise App, or manually log then afterward?
If you manually logged them, your input parameters override whatever data was actually recorded, including heart rate.
Best Answer04-11-2020 20:00
04-11-2020 20:00
I logged the Spinning workout using the app....
Best Answer04-11-2020 20:15
04-11-2020 20:15
Liker I said, if you manually log the workout, the parameters you input override anything that was recorded, assuming the reason you manually logged it is because you were not wearing the tracker at the time.
Your solution is to use the Exercise App to record the workout. Then there is no need to go back and log it afterward.
See How do I track my workouts with my Fitbit device?
To get started, from clock face, scroll right (swipe left) to 'Exercise'.
Best Answer04-11-2020 20:46
04-11-2020 20:46
I think I may not have used the correct terminology, but I did not log anything manually....
thanks!
Best Answer04-11-2020 20:48
04-11-2020 20:48
I had the Polar4 with a heart rate strap that was really most accurate...so not happy with this purchase😔
Best Answer04-11-2020 20:53
04-11-2020 20:53
Fair enough. I was just trying to help you get best results of what you have.
