10-04-2018
03:18
15:47
10-04-2018
03:18
15:47
I work on construction sites. I move my hand a lot. And every time i do i get a small vibration and the screen turns on. Is it possible to turn this function off on the Fitbit 3 ? It eats a lot off battery also. I got mine on Sunday and yesterday i had 10% battery left.
Moderator Edit: Updated Subject for Clarity/Format
08-12-2019 10:39
08-12-2019 10:39
Thank you, simple and it worked 👍😀
08-14-2019 08:25
08-25-2019 12:04
08-25-2019 12:04
Thank goodness. This was driving me mad, waking me up every time I moved my arm.
08-26-2019 09:26
08-26-2019 09:26
@matildamac Welcome on board. We're glad to hear this post was helpful to you.
I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else we can do for you, please keep us posted!
05-06-2020 06:52
05-06-2020 06:52
I do not find a quick view option for the Fitbit Charge 3.
05-06-2020 06:58
05-06-2020 06:58
I do not find a Quick View setting in the options for my fitbit charge 3. Can you be very specific, please.
05-06-2020 07:01
05-06-2020 07:01
I do not find a Quick View option on the dashboard for my Fitbit Charge 3. The Screen Wake button does not respond to a tap on my Fitbit Charge 3.
05-06-2020 07:14
05-06-2020 07:14
Hi @joan5555555555 - as @roadhouse11 mentioned, you can do this:
From the charge 3 on your wrist, press and hold the side button until the Quick Settings menu appears. Scroll to find the Screen Wake option and tap it on/off
You can also find instructions in the Charge 3 manual on page 17.
05-06-2020 07:23
05-06-2020 07:23
05-06-2020 07:37
05-06-2020 07:37
@joan5555555555 - The next thing I would suggest is to re-start your Charge 3. Do it several times. Sometimes that is enough to snap things back to normal. If that does not work, you can contact Support. But please be patient with them. The pandemic is affecting staffing.
05-06-2020 07:44
05-06-2020 07:44
