10-23-2018
09:25
15:03
10-23-2018
09:25
15:03
The step counter on my fitbit 3 is not bright enough to see, if it was the same as the clock face there would be no problem, can it be done??
01-10-2020 07:57
01-10-2020 07:57
Similar to my problem. I tried going into a bathroom closing the door with all the lights off and I could see just the faintest of a display. Like I said customer service should be able to get you straightened out.
WSS
01-10-2020 08:24 - last edited on 01-26-2020 14:26 by LiliyaFitbit
Thanks. I appreciate your help. I was finally able to get the room dark
enough (and also took out one contact so I could see much better up close)
and was able to put mine back to normal. I had not changed that setting in
the first place so that aggravated me. Thanks again for your help.
Sent from Gmail Mobile
01-21-2020 14:47
01-21-2020 14:47
The screen is not bright enough for me to swipe it to get to the settings to0 change it- can I change it through the app?
01-21-2020 15:56
01-21-2020 15:56
Best Answer01-25-2020 10:06
01-25-2020 10:06
Well, I was finally able to get to settings and increase to Normal. That worked until this morning and now I’m back to a very faint screen. I was able, in a dark room, to see Settings and check the brightness. It’s still on Normal!!!!! I’m about ready to throw it away and buy another brand.
01-25-2020 13:13 - last edited on 01-26-2020 14:26 by LiliyaFitbit
You can’t make changes to the brightness through the App. This can only be
done on the watch itself. You will need to contact Support as I have done.
Best Answer01-27-2020 12:09
01-27-2020 12:09
I was having the same issue. Can't read my steps, clock face faint, etc.I went into settings and made the mistake of touching 'auto'. Now I can't read the screen at all, so no way to get back to settings. I try resetting it and that didn't work. Any more advice? Thanks!
01-27-2020 12:30
01-27-2020 12:30
CatG31, I’m going to assume you clicked on Dim and not Auto. Try going into a dark room to see if you can see the display at all. Hopefully you will be able to change it. I have contacted Customer Service for mine.
Best Answer01-27-2020 14:50
01-27-2020 14:50
Best Answer02-04-2020 13:27 - last edited on 02-14-2020 17:29 by LiliyaFitbit
I have a Fitbit Charge 3...and the Fitbit App in both an Android tablet and a Huawei P20 Pro phone. Nowhere under Settings can I find a brightness Control. Please explain how I adjust my Fitbit screen brightness from the phone or tablet using the Fitbit app. Thanks.
Best Answer02-04-2020 13:31 - last edited on 02-14-2020 17:28 by LiliyaFitbit
The only way to change the brightness is on the Fitbit itself. Sadly it
can’t be changed through the app. I had to start a Chat with Customer
Service and am now getting a replacement.
Best Answer02-23-2020 23:03
02-23-2020 23:03
I have done that countless times!! also tried resetting, starting the watch all over again, you name it! and it still doesn't get any brighter. It's truly disappointing!!! I love the watch, but if I'm unable to see the screen what's the point in using it??!!
Best Answer02-24-2020 14:12 - last edited on 06-12-2020 19:44 by LiliyaFitbit
Go to Customer service and work with them. They replaced mine.
Best Answer02-24-2020 14:50
02-24-2020 14:50
Best Answer02-24-2020 14:57 - last edited on 06-12-2020 19:45 by LiliyaFitbit
Good luck.
Best Answer02-25-2020 02:23
02-25-2020 02:23
I need help!!! please contact me asap// My new Charge 3 not sending the accurate numbers to my challenge rooms..Cannot get help thru support!!! 🤯🤯🤯
Best Answer02-25-2020 04:07
02-25-2020 04:07
Keep trying. Support was very helpful to me after they made me jump through a few understandable hoops. Just to make sure the problem wasn't on my end. When it was clear the glitch was in my Hardware they sent me a new one.
WSS
02-25-2020 04:52 - last edited on 06-12-2020 19:45 by LiliyaFitbit
Not sure I understand what you mean—right numbers in my rooms. Please give
more info.
Best Answer02-25-2020 04:54 - last edited on 06-12-2020 19:45 by LiliyaFitbit
Exactly. I took pictures of my Charge 3 in a dark room and in a normally
lit room so they could “see” my issue.
Best Answer02-25-2020 11:54
02-25-2020 11:54
